So I bought this 03 fxdx 3 weeks ago. Rode it everyday since, today while riding i lost all power and the bike had no power, no lights on the speedo, nothing. I figured either the stator wasnt charging the battery or i had a loose connection.
2 hours of sitting on the side of the road my buddy picks me up with his truck, we get the bike home i turn the key and it has power and starts right up.
i decide to take the battery out and the fuse cover and check all connections, make sure everything is tight and it was. I checked the ignition switch and it was getting currency through all the terminals so that wasnt an issue.
I put it all back together and now the speedo light and odometer turn on in accessory but turn the key to run and everything shuts off. I have no idea what is going on. Gotta be a short somewhere but i can find anything. i pulled fuses 1 by 1 to see if i could rule out a part of the electrical system and nothing changed
And by getting super frustrated i broke the damn frame ground under the seat. So if anyone has a good idea on a solution for that it would be greatly appreciated
Start at the bttry.., with a VOM and wiring schematic (or at least a diagram of the wiring harness)
Start tracing it out - clean / tighten all connections - verify voltages
Find all grounds - clean / tighten / verify
Verify all relays - clean their contacts or replace if necessary
Could be a shorted wire..., could also be a hundred other things
Ghost
worst answer ever guess ill be chasing wires for while, just weird that it shut down mid ride. The battery was at 12.8v when i got home so i know the charging system is working. ugh
Is there anything special to do with the security system? Am i supposed to have a fob? when I look at an exploded view of the security wiring it mentions having a coded fob
What was the outside temperature? If it was a hot day and your bike was running hot, then it may be a solenoid issue that is temp related. Purely a stab in the dark but having it fail mid-ride and re-start leads me to believe it is temp that is causing the electrical failure.
It was hot probably 90. But it sat on the side of the road for 3 hours without any power then I get it home and it acts like nothing happened. And after checking for loose wires and getting it all back together now it just died if I switch the ignition to run.
In accessory the speedo lights up but if I try the horn it shuts off and the horn doesn't work
i am going to second the switch i would check the power to the switch when you loose everything if you still have power at switch when nothing works it is the switch
