Front wheel rim change?
Has anybody done anything like this? The other problem this gives me is what type of front fender could I use? I'm guessing I'd need to modify a Fay Boy fender.
Thanks for your help (I hope)
Just have a look on the end of the page two of this forum!
Don't hesitate to as questions about that mod. I will try to help.
Gunny.
[IMG]local://upfiles/32536/0EAAC3533D654F69A240F3CFDB83C694.jpg[/IMG]
[IMG]local://upfiles/32536/E74C58237B924DCAB5D9F8E1077975D8.jpg[/IMG]
[IMG]local://upfiles/32536/38C31BBBE7774FFC9612B66BA7EB2EB2.jpg[/IMG]
Zippo
Here is the detail of the front wheel assembly:
Stock frond hub and spacers.
Special fabrication stainless steel spokes for 17" rim.
Morad 3.5X17" alu. rim.
Dunlop D205 (Fat Boy Screaming Eagle) 140/75RX17" and the right tube!
Home modified BK Pro Comp 150mm. wide front fender #909349 from Motorcycle
Storehouse in the Netherlands. As you may see that specific fender have the
profile of the rear one. It was one of the reason I choose it!
Rim and special spokes set came from Hann Wheels also in the Netherlands
(www.hannwheels.com).
I did cut the front fender on the front sides for the new Dyna's fork legs.
I also tig welded a right and left 5mm. thick spacers Threated 5/16 UNF (as
you don't have a lot of place!). I'v give them the profiles of the fender
attachement of the legs.
It handle as a dream and is very stable at any speed on any kind of road.
If you love it done it you will not regret and it's a cheap mod!
About your air filter if you just have one wire I don't konw what it is! European models (I live in Belgium)have two wire and is call an active air system which allow a "door" to open for more air intake at a moment.
Gunny.
[IMG]local://upfiles/32536/C4996049939340DBA05CE116DBB076A5.jpg[/IMG]
[IMG]local://upfiles/32536/4735790E7490493DA34D8EB81441EC63.jpg[/IMG]
[IMG]local://upfiles/32536/5F6C8A542E0143BBAB596791A2BFA653.jpg[/IMG]
[IMG]local://upfiles/32536/EA9C6C076B6042448D84F6D83ED395A9.jpg[/IMG]
On the subject of the wire behind the filter backplate again......
What I have is a cable (2 wires) which I've just unplugged from the connector on the backplate. If I just tie it up out of the way will I get some sort of warning light coming on? I haven't noticed anything, but then I've only just done it. If I need to plug something into the connector, what is it and why?
As Motorcycle Storehouse don't do retail sales you must ask your favorite dealer to contact them by phone to clear because I bought mine just a month ago!
As you are living in England you shouldhave an HDI model and the same "active air intake" that I have on my Bob.
If you simplyunplugyour warning engine light should come on and stay to let you know of a technical problem like for a sensor. If it doesn't I don't understand as minedo!
The solution is to buy from your Zodiac distributor an electronic adapter for active induction system, part. n° 702022 which alloy you to place any kind of air filter without that problem.
Let me know!
Gunny.
The price here three weeks agowas about 28⏠which is 19£. Ok, it ismay be too much for as you said, just a resistor, but as I don't know what is inside thatsmall blackbox...
Anyway, if you stay in trouble to get it and still want to have one, I may buy it for you here in Belgium and ship it to your address in G.B. (e-mail me).
Gunny.
I can't believe HD don't have a solution for this. My local HD dealer said their answer was to break open the OE backplate and pull out the mechanism, wrap it up in a plastic bag, plug it back in and cable tie it out of the way somewhere.
