FXDF floating front disks stopped floating.
Old Sep 26, 2016 | 08:00 PM
watoad's Avatar
watoad
Default FXDF floating front disks stopped floating.
When I got my Fat Bob new from the dealer the front brakes made a ticking noise that I assumed was the floating disks moving laterally to eliminate pulsing. Now I have no noise except the occasional wisp as the disk touches the pads but, I also have pulsing while braking. So, are they supposed to be serviced? There is nothing other than minimum thickness in the Service Manual. I don't want to lube the floating rivets! Can't just be a problem on my bike. Are they trash now?
Old Oct 4, 2016 | 09:06 PM
watoad's Avatar
watoad
Default I figured it out. See new thread
I don't know how to stop this thread and start a related new one so please search for:
Servicing stock H-D Floating Disks is NOTexplained in the 2010 H-D Service Manual for Dyna Models
Old Oct 5, 2016 | 12:41 AM
JustOneDean's Avatar
JustOneDean
I don't know enough about floating vs. solid rotors to tell you anything about that ticking noise, but generally, if you're feeling pulsing in the pedal, you could have a warped rotor. Take a straightedge (it needs to be truly straight), lay it on the rotor, and see if you can stick a feeler blade between it and the disc. Harley's warpage spec is eight thousandths of an inch (0.008).
steelpony16
Jul 28, 2014 10:05 PM
SeniorChief56
Wheels/Tires
Feb 4, 2014 07:58 PM
HKWildHog
Aug 9, 2012 11:28 AM
smokinfromshootin
Sep 13, 2010 09:53 PM
RocketRocker
Dec 7, 2009 05:20 PM
