Slowing down
Old Dec 6, 2009 | 05:02 PM
RocketRocker's Avatar
RocketRocker
Default Slowing down
Front brake makes loud noises while slowly squeezing the lever...no noise when I squeeze it hard. Maybe I missed something while replacing front pads with the Lyndal pads. Its obnoxious as hell....any help would be greatly appreciated.
Old Dec 6, 2009 | 06:27 PM
fastcash0523's Avatar
fastcash0523
Mine makes noise too. It seems the holes in the rotor do it.
Old Dec 6, 2009 | 06:35 PM
lnrider's Avatar
lnrider
try installin a left (stock) rotor. The factory suggests baggers swap their rotors from one side to the other, and it seems to work.
roll on
L
Old Dec 6, 2009 | 08:21 PM
RocketRocker
My stock one is on the left...hmm. This one has me stumped.
Old Dec 6, 2009 | 10:03 PM
Other Sheep's Avatar
Other Sheep
Did you grease the backs of the pads and the pins when you replaced the old with the new? That's usually where the noise will come from.
Old Dec 7, 2009 | 01:04 PM
DMorr99's Avatar
DMorr99
I say grease the rotor and hang on!
Old Dec 7, 2009 | 01:08 PM
DECON BLUE's Avatar
DECON BLUE
Talking
You do not use grease, there is a product that you put on the back of the pads, it has to do with brake dust and vibration between pad and piston.
Old Dec 7, 2009 | 01:59 PM
Mordrapheus's Avatar
Mordrapheus
lol
or less dangerous just remove the offending parts!
lol
Old Dec 7, 2009 | 02:36 PM
Haulen Ass's Avatar
Haulen Ass
Former Sponsor
Sounds like you just need to wait a little longer and really hit the brakes. Do the disks have any grooves or anything in that which might be causing an uneven surface area?
Old Dec 7, 2009 | 03:23 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
I run Lyndall's and have NO noise at all.....they squeeked (very lightly) for about 150 miles or so... but now are quite as can be...
Take them off and check if pads are clipped in correctly. Also check to see if your calipers are tightened correctly.
Sometimes going through it a second time fixes your problems...
Putting grease around pads is nuts....
