speed wobbles
Old Oct 1, 2016 | 06:38 PM
chriswillrise's Avatar
chriswillrise
Originally Posted by Nemosengineer
Check the swingarm bearings/bushings for play, remove the rear wheel and the lower shock mount bolts, zip tie the shocks out of the way.
Any side to side movement or click-click movements at the axle end means its time to rebuild the pivot.
: Mike
ill check that this coming week along with the rear bearings. Im getting a new tire on the back for ill be tearing into that
Old Oct 1, 2016 | 11:46 PM
NORTY FLATZ's Avatar
NORTY FLATZ
What speeds are these wobbles ocurring?
Old Oct 1, 2016 | 11:57 PM
chriswillrise
freeway speeds. 65+
Old Oct 2, 2016 | 04:02 AM
NorthWestern's Avatar
NorthWestern
Originally Posted by chriswillrise
If i loosen my grip on the bars the wobbles stop, if I get a good grip on them I get wobbles. Maybe it's user error? I do usually hold on for dear life on the freeway with all the wind hitting my chest
Yeah, you need to try and relax. Without a head wind, or cross wind you can get used to it up to 65. I often ride with one hand, for a break on long trips at higher speeds. My alignment is perfect though, I can no-hand her, and she is straight as an arrow. Cruise control is so cool. (I don't make a habit of it, calm down)
Is this your first bike? Just curious. I have a buddy that got his first, and he is having some similar issues, that seem to be confidence/comfort driven.
Old Oct 2, 2016 | 09:41 AM
chriswillrise
this is my first cruiser, ive had a couple crotch rockets. First bike that ive got all that wind hitting me strait in the chest it was a little uncomfortable but im getting used to it
Old Oct 3, 2016 | 02:50 PM
monstrosity's Avatar
monstrosity
Stage III
The fact that it is worse when you hold the bars tightly really points to an untrue front wheel or tire. Get the front end off the ground and spin it, watching for any side to side movement as it rotates. It could be something that simple
Old Oct 4, 2016 | 07:51 AM
leafman60's Avatar
leafman60
If not steering bearings, the problem could very well be the wheel bearings. This is especially true if you are using the cheap oem H-D bearings.
Check the wheel bearing threads here and get a set of quality bearings like Timken/Fafnir etc. I've posted the part numbers.
I had this problem too. Wheel bearings fixed mine.
Look here-
https://www.hdforums.com/forum/dyna-...el-wobble.html
Old Oct 5, 2016 | 10:36 PM
crtman21's Avatar
crtman21
I got my first bike...EVER last year. My bike would wobble at highway speeds as well. I was nervous and tense for months and once I learned to relax it I got more comfortable. When I took the bike in for it's first service, they added a few pounds to the tire and some weight and the wobbles went away. I didn't like the wind on my chest. It felt like I was holding on for dear life. So, I got a fairing and it made a HUGE difference in my comfort level. I'm sure a lot of others can attest to this as well. It might be something to think about as far as comfort.
Old Oct 5, 2016 | 11:04 PM
chriswillrise
honestly i havnt gotten wobbles once I relaxed my grip. I can pull my hands off the bars at 80+ and its strait. Still a little wobbly in fast turns but ive read thats common in the rubber mounted dynas. need a true track or similar to get rid of that
Old Oct 5, 2016 | 11:22 PM
Ghost_13's Avatar
Ghost_13
Now ain't that amazing
Undoubtedly..., from people who don't know **** about setting up a bike
True track or similar does help
Ghost
