I'm new to the forum and have a question about my regulator. So, my battery and engine light came on together, that means the charging system is sucky.
So, I got my voltmeter and got a brand new battery. Standing charge was 12.7 volts with DC on the voltmeter.
I fired up the bike, it was reading 12.3 volts while running (automatically I assume it's the regulator), the manual says it should be at 14.2-14.7
Just to double check, I set the voltmeter to AC and pulled the stator plug and put the probed in which reads 23-26 which is all good.
Did I miss anything or did I do this right?
Start at the stator..., then work (troubleshoot) out..., eliminating one thing (component) at a time
