Lifter replacement
Old Oct 6, 2016 | 01:45 PM
CLukens's Avatar
CLukens
6th Gear
Default Lifter replacement
My 15 Street Bob started making a noticeable clicking noise when cold then started sounding sick. Took it to the dealer under warranty (4700 miles) and they replaced all the lifters. What the hell would have caused that kind of failure after only 4700 mile??
Old Oct 6, 2016 | 02:26 PM
TinCupChalice's Avatar
TinCupChalice
Accountants and stockholders are why those lifters fail; I've read of many people posting on different forums having lifter/tappet issues on newer HD's. They're outsourced to who know's where now, it's the bottom line that matters; I've been lucky with my '13 but I fully plan on new S&S lifters/tappets when I do my cams and heads very soon...
Old Oct 6, 2016 | 02:35 PM
TUCCI's Avatar
TUCCI
I had the same problem with my RK at around the same miles. After being tired of all the noise I tried experimenting with conventional oils. I decided to run conventional for 500 miles to see if anything changed. After 300 miles or so the engine all of a sudden quieted down. Using synthetic oil has been know to cause excessive bleed down of the lifters because of how thin the oil gets. What kind of oil are you using?
Old Oct 6, 2016 | 02:58 PM
CLukens's Avatar
CLukens
6th Gear
I am using HD syn3.
Old Oct 6, 2016 | 08:43 PM
MRFREEZE57's Avatar
MRFREEZE57
on a few occasions, on a cold morning, have one that clicks a few seconds. still have I believe a lifter noise between 22-28k rpm, have installed rocker lockers. am thinking this winter to also replace lifters with the s&s.
Old Oct 6, 2016 | 10:23 PM
stilup's Avatar
stilup
Unfortunately times are tight and out sourcing parts are not helping the HD image.
It's all about cutting cost.
SS high performance lifters are the way to go.
Half the fun of owning a newer HD is rebuilding it to the way it should of been made in the first place.
If you want a bike that is going to go the distance you need to improve it .
I hope to have mine for over 100K,
ShaZAM
2014-2024 Touring Models
13
Apr 5, 2017 08:14 PM
sbarnes489
May 6, 2015 07:54 PM
Bowhunter61
Sep 21, 2014 01:18 AM
wildrider
Sep 5, 2010 02:33 PM
detnight
Exhaust System Topics
Nov 7, 2008 06:12 PM
