Steering Stabilzer
Old Oct 8, 2016 | 10:03 AM
Tjessie87's Avatar
Tjessie87
Default Steering Stabilzer
Anyone using a steering stablizer? What kind?
I ride pretty hard and when turning at 80 i get some waviness through the turn.
Old Oct 8, 2016 | 11:13 AM
F86's Avatar
F86
Are you certain that the issue originates with the front wheel as opposed to the rear? You may be experiencing a touch of what people refer to as the "Dyna Death Wobble." Since the swingarm mounts to the transmission case, the rear wheel is subject movement as the engine moves, which can cause a "rear steer" effect, often most prevalent in high speed sweepers. This can often be reduced or eliminated with a front engine mount stabilizer, such as a True-Track, Sputhe, or Vibra Technics.
If it is coming from the front, I would start with tire pressure, then wheel balance. You may benefit from a steering stabilizer, but you may just be masking a problem that should be addressed.
Old Oct 8, 2016 | 12:56 PM
MRFREEZE57's Avatar
MRFREEZE57
I recently installed a vibratechnics front motor mount, went on a 2k mile trip loaded for travel and wife on back. don't really notice much difference in vibration , but the stability difference is noticeable as I purposely would steer into ruts and they do not create as much wobble as before. the front stabilizer helps a lot.
Old Oct 8, 2016 | 01:43 PM
F86's Avatar
F86
Yup. I just got back from 950 miles with 100 lbs of baggage/gear which literally included everything from 90 mph highway riding to unpaved dirt trails. I have a VT Predator mount as well, and it really helps with handling and stability. As you pointed out, if people install this mount primarily to control vibration they may be disappointed... But I was after handling and stability and it works very well.
Old Oct 8, 2016 | 02:28 PM
Max Headflow's Avatar
Max Headflow
I have a PMFR stabilizer on my 2000 dx.. Really didn't make any difference unless you cranked it up so high that you couldn't steer the bike.. Drivetrain stabilizers are better but for me, going to a 180/55 x 18 in the rear was the only thing to cure the problem. Steering dampers are good for curing head shake where the frequency of oscillation is high.. They work very well in controlling dirt bikes that are run at high speed in the sand and sport bikes that are prone to the same issue on the track.
Old Oct 8, 2016 | 05:00 PM
JohnMn's Avatar
JohnMn
Uhm, , I think you might have that term messed up with something else
Old Oct 8, 2016 | 05:03 PM
F86's Avatar
F86
What was involved with running this tire/wheel combo on the FXDX? It's not right on my horizon, but at some point lighter-than-stock wheels may be in my future, which would be a good time to consider a size change...
Old Oct 8, 2016 | 07:00 PM
hell hound's Avatar
hell hound
if you have a large fairing or windshield the damper makes a big diffeerence
I had a cheap ebay damper on my 06 and it was great except when it started leaking 3 times. I went thru a few of them at no cost then never even installed it on my 14.
the steering damper is bad *** on a dyna. You can do interstate uturns under the over pass with one hand on the bars. I would get another one for my new bike but the good ones are high dollar
Old Oct 8, 2016 | 07:41 PM
Max Headflow
It's a bit of work.. Need to straighten the rear fender brackets out on the frame to fit a 7 1/2 inch fender.. 8 inch would be better as 7 1/2 is snug.. Go to chain drive. Get all the spacing right..
grbrown
Apr 25, 2024 11:26 AM
wastedranger
Nov 13, 2019 03:51 PM
Valleyofthegun
May 5, 2019 02:20 PM
wscott
Oct 16, 2015 11:26 PM
rauchman
Jul 29, 2015 09:10 AM
