Tru-trak
Old Sep 19, 2014 | 07:17 PM
wastedranger's Avatar
wastedranger
Default Tru-trak
Anyone use this? Sounds pretty good. But does adding stabilizers to mounts defeat purpose of rubber mounting? I notice they do not make them for softails.
Old Sep 19, 2014 | 08:21 PM
HD Pilot's Avatar
HD Pilot
Dynas and the baggers are the bikes that are prone to rear wheel wobble because of their frame/swingarm design. If you are experiencing rear wheel wobble during hard cornering then yes they work by limiting the engine from shifting laterally. Vertical vibrations will still be reduced by the rubber mounts.
Some people say they never get rear wheel wobble even though they ride their bikes hard while others like me got the wobble numerous times and frankly it is not a pleasant experience. The True Track eliminated the wobble for me, so I am happy but I will tell you that there are people that swear that the stabilizers are not the cure and that it is some other issue with the bike. For me, problem fixed - done deal.
If you have not had any wobbles though, then probably not needed.
Old Sep 19, 2014 | 08:24 PM
sigmoid's Avatar
sigmoid
Softails aren't rubber mounted so don't need these. The point of the tru trak is that the swingarm is mounted to the engine which is rubber mounted. The rear mount prevents the swingarm from moving laterally relative to the frame. There is some increased vibration as a result but it doesn't bother me. For the best results install both front and rear mounts. The rear is a booger to do but the front is easy. It improves the handling and stability of the bike at speed considerably.
Old Sep 19, 2014 | 08:45 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
I put the true track stabilizers on a 2005. I did feel a bit more vibration but not enough to worry about. Handling improved only slightly but i already had FXDX suspension and fork brace. The front mount is super ugly but it can be hidden underneath a front spoiler.
Old Sep 19, 2014 | 11:02 PM
IdahoHacker's Avatar
IdahoHacker
I was under the impression that the stabilizer could be installed by itself. Do you need to replace the motor mounts as well, even if the bike is fairly new?
Old Sep 20, 2014 | 03:29 PM
HD Pilot's Avatar
HD Pilot
No, the stock engine mounts stay on.
Old Sep 20, 2014 | 06:09 PM
IdahoHacker
Thanks!
Old Sep 20, 2014 | 06:26 PM
jmb79's Avatar
jmb79
As stated above, if you are not experiencing rear wheel wobble, don't waste you money on a True Track. So far, I've not needed one.
Old Sep 20, 2014 | 06:31 PM
IdahoHacker
Unfortunately, I have. More than once.
I have a Super Glide because I like to ride. The first time I was banked into a hard curve and it started dancing I almost sucked the seat right up through my jeans. I told the dealership about it. They retrued the rear wheel spokes. Happened again. At least this time I knew I wasn't going to die, but it's still a very frightening thing.
Old Sep 21, 2014 | 08:07 AM
wastedranger
Was just wondering about the whole rigidity thing. If it is rubber mounted for a reason I was confused as to why you would want to stiffen it up. Was just talkin to dealer at the booth Friday. I have never experienced the wobble although I have gotten it wild into some hard cornering. Don't think it was the wobble just the tire being pushed to hard. Wanted to know from guys using it and not the guy trying to get me to install it at the show. Lol! Oh he has his bike there with it installed.
