optimal rpms?
Old Oct 29, 2016 | 12:38 AM
offbeatmammal's Avatar
offbeatmammal
Question optimal rpms?
I seem to spend most of the time on my 05 FXDLi (88cu, 5 speed) fairly low in the rev range - around 2-3k. Anyone got any pointers for optimal rpm/speed bands to minimize rattle, keep noise down, and look after the engine.
I came to the v-twin world from high-revving sportbikes and still find judging the noise/revs to be an interesting exercise ... am I running too low, will it be happier if I run it higher?
Old Oct 29, 2016 | 07:26 AM
cvaria's Avatar
cvaria
trust your butt. 2-3k is nearly lugging the engine. these bikes are loud, make mechanical noises
owners manual:
https://www.harley-davidson.com/en_U...na/file-6.comp
to get to different parts of the manual, modify the "file-[x].comp" portion of the address. the [x] is the chapter, there are 14 total.
e.g. chapter 6 = file-6.comp
i'm sure someone has an rpm chart, i can't locate one
Old Oct 29, 2016 | 09:41 AM
Just Nick's Avatar
Just Nick
above 3k is where the motor will be happiest
Old Oct 29, 2016 | 09:43 AM
Whtwolf14's Avatar
Whtwolf14
My Dyna likes being run at cruising speed, butt dyno, between 27-30k. I rarely hit 6th gear where I ride, that's in 5th
Old Oct 29, 2016 | 09:49 AM
TriGeezer's Avatar
TriGeezer
Damn!! Them r some serious revs!!
Old Oct 29, 2016 | 12:08 PM
nevil's Avatar
nevil
Most of the rpm's I log are between 2500 and 4000. With more than the occasional visit well above that!
Old Oct 29, 2016 | 12:27 PM
offbeatmammal
time to turn up the noise a bit
Old Oct 29, 2016 | 01:27 PM
Greezey Rider's Avatar
Greezey Rider
I prefer to keep it well above 3000...
Old Oct 29, 2016 | 01:49 PM
Uncle Sam's Avatar
Uncle Sam
I usually like to ride around town right at 3,000 rpm. it keeps you on the power and torque while not lugging the engine. Even though big twins do not seem "happy" being revved, higher in the RPM range, I just ignor it and beat the he'll out of my bike... and she likes it.
Old Oct 29, 2016 | 02:18 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
2-3 k works fine for me. I shift 2500 or so. I can ride down to 1700 or so. Same 88TCb with 5 speed. Mine seems a bit rough at 4K and above. It will last forever at that. It's pretty level here and maximum HP at sea level. Usually, coming off 1700 is very easy on throttle or I drop a gear. I have no problem being in 5th over 45mph
