Winter upgrades
Old Nov 5, 2016 | 06:36 PM
Sportylee's Avatar
Sportylee
Default Winter upgrades
I'm getting ready for some winter up grades. I want to put a 23" front wheel on my wide glide will I need to get raked bushing to keep the handling close to stock? Also plan to put a new rear tire on bit I really like Avon tires and can't find the 180/60/17 I can fine a avon 190/60/17 or go with the 190/55/17 to get alittle more take off power from the bike will that fit I know it's alittle wider then the stock tire. Or is there anyone that makes a good grippy 180/60/17 rear tire? Thanks
Old Nov 5, 2016 | 07:57 PM
cggorman's Avatar
cggorman
Everybody raves about the Pirelli Night Dragons.
I have no idea what a rake bushing is. Raked.bearing cups in the neck, maybe? Does going to the 23" push your rolling diameter way up? If so, you maybe meed to lower the front end a bit.
Old Nov 5, 2016 | 11:27 PM
Reaperhd's Avatar
Reaperhd
I run a 180/55/18 metzler and its super sticky. It may be a 180/50/18 either way it grips wet or dry.
Old Nov 6, 2016 | 05:57 AM
stilup's Avatar
stilup
plus one on the metz
here is a little chart online to help with tire height
I raised my rear shocks 3/4" but lost that height with the tire so it balances out.
METZELER ME880 MARATHON 170/60R-17 M/C 78V dia 25.031 cir 78.637 Metz with the higher excellent tire weight rating! (78V) best for two up.
DUNLOP K591 160/70B-17 M/C 73V, REAR 25.819 81.113
AVON STORM 3D X-M 170/60ZR-17 M/C (72W) 25.031 78.637
AVON STORM 3D X-M 180/55ZR-17 M/C (73W) 24.795 77.896
http://www.csgnetwork.com/tiresizescalc.html
Old Nov 6, 2016 | 06:23 AM
HrdNox's Avatar
HrdNox
This is a 23"...Sure you want to go that big?
Attached Thumbnails Winter upgrades-pintail.jpg   Winter upgrades-3db40d_367ab913a5884b52b7b124c0194cca37.jpg
HDMLNIUM
Jun 19, 2016 05:49 PM
buick455gs
Feb 24, 2011 04:00 PM
jbhawley
Sep 30, 2010 03:25 AM
Seascape
Sep 4, 2009 11:15 PM
Mr Wasabi
Aug 17, 2008 07:20 PM
