FXDX RaceTech Gold valves
I've been on the fence about doing it myself or sending my forks to RaceTech, as their labor pricing really doesn't look bad, and that would free up my limited garage time to focus on a few engine-related things over the winter. Hopefully your experience and result will help me decide!
There is a video series on YouTube. It's old and it's dirt-bike focused, but it appears it will be a similar process on the DX forks. Parts 1-5.
https://youtu.be/gAYO4FIlv1Q?list=PL...My1nxUp3ELaXzk
Ive looked numerous times for info in installation but came up empty every time. I can't for the life of me figure out how they install on these front ends. Any info is appreciated!
I put them in my front end.
There is a few pictures that I took as I did them.
Not to hard to do if you have the proper tools.
I tackled this over the last few days and all I can say it that its very frustrating. After using the HD service manual and experience from my previous bike (FXDXT) I got everything back together. The springs are installed and so are the compression and rebound valves, that was the easy part honestly. The vague part is how much oil to put in the forks because the manual doesn't give a measurement in a fluid amount, its measured from the top of the fork tube (with the tube bottomed out in the leg) and it states fill up to 4.4" from the top of the threaded tube. Ok thats what the manual says so it must be right. My issue now is that theres plenty of compression but 0 rebound whatsoever. when the brakes are applied, the bike compresses down, but does not rebound until the bike is under acceleration if that makes sense. My springs are fairly light, Im 135lbs with gear, so I have light springs. Im using HD type E oil, which someone correct me if Im wrong, but I believe it equals to 10wt.
The bike feels as if my springs are sprung for a 80 pound person. Theres just no reaction in the suspension. I know for a fact the oil measurement is correct and everything is installed correctly. Im stumped, the only thing I can think of is I need thicker fork oil, which to change requires to disassemble the entire fork and redo it all over again.
Sorry for the long post, but I like to try and be detailed. any advice is much appreciated. Im this close to taking it to RT since they're local to me and having them solve/fix my issue. I just want to ride the damn thing!
Amy does this Video step by step. Again, I do not use the RaceTeck products for that job. I get tired of explaining why you do not use heavy fork oil when you are using shims. Put some honey in a refrigerator and observe putting in that take out a spoon of the honey jar at both room temperature and once again after cooled. That is how your suspension acts. Want it slow than make sure you put in heavy oil. If you actually want the wheel on the ground than use the suspension for what is is used for.
I am doing this same job to 3 sets of XR1200 inverted forks today that is being converted over to Dyna application with my trees to put your trail at 4" on stock 29 degree necks.
IMO you will need all of the tools I use in the video. If you do not have use of all of them, my advice is to rethink your plan. I would also not use this forum to get advice unless that person actually will give you useful information and actually knows about suspension, your choice. Good luck with your install.
