Dumb handlebar question, sorry in advance
Old Nov 19, 2016 | 12:53 AM
Torpedo1's Avatar
Torpedo1
Default Dumb handlebar question, sorry in advance
I'm looking to experiment with some handlebar positions via rotating the mini apes on my Street Bob. I always felt they should be rotated back just and inch (they are currently just straight up) so my shoulder doesn't cramp.
I read other threads on the subject and it seems you just loosen the clamps, rotate, tighten.
The Harley service book is on my Christmas list - anyone know what tightening sequence and torque specs to use? I'd rather not have them slipping by not getting it right.
Also, is there any need to mess with adjusting the throttle or that wouldn't be affected?
I know it's a dumb question, but any info would be most appreciated.
Old Nov 19, 2016 | 01:27 AM
Ghost_13's Avatar
Ghost_13
12 -18 ft lbs
Tighten/ torque rear two first - then tighten / torque front two
Personally..., I alternate tightening down all four for equal loading
Ghost
Old Nov 19, 2016 | 12:25 PM
buggy's Avatar
buggy
May need to loosen the switches and levers mounts and roll to where your comfortable.
Old Nov 19, 2016 | 01:17 PM
Fireguy88's Avatar
Fireguy88
I doubt you'll need to adjust your throttle cables or clutch cable with such a small movement. Don't know for certain though. If you do notice a change it's pretty easy to adjust them both.
Old Nov 19, 2016 | 04:14 PM
TUCCI's Avatar
TUCCI
No such thing as a dumb question....ask away, we've all been there.
Old Nov 19, 2016 | 04:18 PM
Ghost_13's Avatar
Ghost_13
Shouldn't.., nor the clutch
What you may need to adjust however, is the angle of your levers - after you've set the bars
Forgot to mention that last night
Ghost
Old Nov 19, 2016 | 06:02 PM
Torpedo1's Avatar
Torpedo1
Genuinely appreciate the tips, thanks everyone (especially the torque values). Got it adjusted without issue, now all that's left is to take it for a spin to find the sweet spot.
Old Nov 19, 2016 | 06:19 PM
JustOneDean's Avatar
JustOneDean
Before you ride it, turn it on and with it idling, turn the bars from full left lock to full right lock a few times, just to make sure your throttle cables don't need to be adjusted. If the RPMs change when you're turning the bars, that means you're tugging on the cables and opening the throttle, potentially dangerous if it happens while riding.
Dobe66
Apr 27, 2015 09:47 PM
Whitebrad25
Mar 19, 2014 09:24 PM
popstheoldman
General Topics/Tech Tips
Oct 6, 2010 10:18 PM
clayharley
Mar 15, 2010 03:05 PM
greenandgold
Apr 11, 2009 05:50 PM
