Big Sucker - Normal?
Old Dec 15, 2016 | 11:00 PM
Torpedo1's Avatar
Torpedo1
Got the kit from DK quick! Ordered Monday, received this afternoon. Drilling and tapping went fine, but when I went to put the backing plate back, I could only get the black posts about two turns into the stand offs. I forget how they were originally but I think I stripped the threads when I was taking them off.
So, I had to get a stupid replacement hardware kit to finish the project.
Quick question since I've been unclear on both times I installed a Big Sucker - do you put the posts in the throttle body first, then screw the stand offs on, or do torque the posts into the stand offs, then screw the whole thing into the throttle body?
Old Dec 20, 2016 | 08:13 PM
Torpedo1's Avatar
Torpedo1
Called Arlen Ness and asked about the set screws and they said most people do it wrong - you torque the set screw into the stand off, then put that into the throttle body plate. That's what I've been doing but posted for anyone also curious.
Last question - I have no idea where to route this hose on my Street Bob. Looked at photos on threads but couldn't tell how it should go. I was thinking to attach near the front of the bike but didn't see anyone else doing that. It's my last step, any ideas?
Old Dec 21, 2016 | 07:21 AM
NC Rob's Avatar
NC Rob
People have all different ideas but I am a bit leery about venting it under the bike and getting any oil on my tire(s). I use a cheap crankcase breather filter to catch the oil and change it every year or so. You can buy them at probably any of the auto stores, I usually get them from ebay: http://www.ebay.com/itm/291660671298
Old Dec 21, 2016 | 09:26 AM
cggorman's Avatar
cggorman
If you're lucky and don't have a bulimic engine, you can just use breather bolts, but if have a puker, a catch can would be wise...or do it old school and dump it into the exhaust collector where it can be actively scavenged and blown out the back safely.
Old Dec 21, 2016 | 01:15 PM
TUCCI's Avatar
TUCCI
Ive got mine vented under the bike just behind the mid-peg. I dont drop much, when I clean the undercarriage I get any residual frame jizzle. If your putting out enough bb to get it on your tires, its not coming from the breather ports and would look for an oil leak.
Old Dec 21, 2016 | 09:20 PM
Torpedo1's Avatar
Torpedo1
Here's where I ended up putting it, just ran it on the front then bottom of the frame, then put the filter right before my mids. I don't really see anything that would cause an issue with it being there, so that's where it went.
Old Dec 21, 2016 | 09:57 PM
NC Rob's Avatar
NC Rob
Looks great and now you will have a clean breathing engine!
Old Sep 19, 2017 | 06:30 AM
Crankshaft-lffl's Avatar
Crankshaft-lffl
Stage II
Originally Posted by TUCCI
Until you vent that **** to atmosphere, yes it will be normal. Lots of threads on the subject.....do a search and spend some time getting to know the problem. Come back with questions, we're here to help.
ohh so what your saying is the lack of research from the MOCO to provide an engine with pcv that doesn't leak is ok with some of you or the fact we spent 30 grand or so on an oil pump
my self I'm pissed my RGU had a motor put in at 3500 mi
clutch letting lose at hard acceleration
oil leaking from aircleaner
hand grips that spin
they can't fix the problems
love the bike power etc not the problems
Old Sep 19, 2017 | 10:30 AM
nevil's Avatar
nevil
Welcome to the site.
Nice first post/rant.
We might be able to get you some help or answers. Just post your questions with as much info as you can and we'll see what we can do.
Old Sep 20, 2017 | 12:57 AM
Blue Bob's Avatar
Blue Bob
Any system is better than stock EPA dictated puke into intake sytem Harley rollover and die design. Barbeque piston tops quickly.
