Recurring Exhaust Leaks
Old Jan 10, 2017 | 06:55 PM
eLBo's Avatar
eLBo
6th Gear
Default Recurring Exhaust Leaks
I have owned my '07 Super Glide for less than a year. In that time, I have gone thru 3 different sets of headers. No matter what I do, within a few weeks of installing a header, the exhaust begins to leak at the flange. Twice, the flange ring welds broke. I'm referring to the steel rings that are on the head end of the headers, that help to retain the flange.
I've had two different HD techs take a look and they believe the motor mounts are still good... And, that the motor isn't moving all that much. The bike only has 10k on it, currently.
Any ideas? I LOVE this bike... But, it's the issues like this that are driving me INSANE!!!
Old Jan 10, 2017 | 07:13 PM
cvaria's Avatar
cvaria
New gaskets and re-torqued bolts?
Old Jan 10, 2017 | 07:54 PM
eLBo's Avatar
eLBo
6th Gear
New gaskets every time... The flange nuts are good and tight.
Old Jan 10, 2017 | 08:02 PM
Yamaharley's Avatar
Yamaharley
Sounds like the rear mount is putting stress on where the pipe mounts in the heads. Mount it from the heads back, and shim the rear mount accordingly.
Old Jan 10, 2017 | 08:12 PM
eLBo's Avatar
eLBo
6th Gear
Not sure I'm following you.
Old Jan 10, 2017 | 08:17 PM
Yamaharley's Avatar
Yamaharley
If the rear exhaust mount is a little too high or low, it will put pressure on the flanges and cause exhaust gaskets to blow out.
QC's Avatar
QC
Which gaskets are you using?
Old Jan 10, 2017 | 08:48 PM
103 sedona orange's Avatar
103 sedona orange
Are you following the HD Service Manual instructions for your bike? I'm sure someone in the Dyna group can help. Good Luck.
Old Jan 10, 2017 | 08:56 PM
eLBo's Avatar
eLBo
6th Gear
Yamaharley, I understand. Thanks for the clarification.
Old Jan 10, 2017 | 09:00 PM
eLBo's Avatar
eLBo
6th Gear
They're the nice, thick crush gaskets.
