Flush Mount Fuel Gauge/Tank Lift
Ok I've done a whooole lot of reading on this topic here from searching threads. I have an 07 Street Bob. I'm reading that the gauge will be off if you have a tank lift installed, and that the softtail kit reads more accurately for some reason. Can anyone explain why this is the case? I don't rely on the gauge, but if I'm going to put the flush mounts on, I might as well get the better one for my situation.
I also saw a few discussions about different types of softtail kits, but no one was posting product numbers. I can find is 75027-08C and 75020-08C. Can anyone confirm which one is going to work on a 2007 Dyna?
sn95bullitt (01-22-2017)
The gauge really has nothing to do with the readings as I understand it. The gauge only displays the values the in tank sender reads. If you're going to try to install a gauge from a different model, you have to be sure a) the tank fitting dimensions are the same - so it will actually fit, and b) is the pin out/connector on the gauge itself the same.
Why its said that the softail gauge is more accurate is a mystery to me - I've never heard it nor have I had a softail. However the HD fuel gauge is probably the least accurate instrument I've ever seen, the only thing worse are the painted on gauges on toys.
I actually checked the part # for the gauge in each package and they're all the same, so I think someone just had their own take on it that wasn't thought out.
