Mustache engine guard
Old Feb 13, 2017 | 12:23 AM
RocklandTroy's Avatar
RocklandTroy
1st Gear
Default Mustache engine guard
Hey everybody I just bought a Mustache engine guard from harley, I have oem forward controls and the brake is hitting the engine guard when I push the brake. I called the store and they said it was the right one for my bike (2010 superglide custom). I even loosened the rod from my brake to raise it up and that only helped a little. Anybody else ever had this issue?
Old Feb 13, 2017 | 06:43 AM
blueangel73's Avatar
blueangel73
I installed my guard after I installed the footboards, so I don't have the issue you do. Do you have any pics so we can see what you're up against?
Old Feb 13, 2017 | 06:57 AM
shorelasHD's Avatar
shorelasHD
No issue with the mustache guard on my 2014 FLSTC...
Old Feb 13, 2017 | 08:03 AM
Nickd2689's Avatar
Nickd2689
Have you tried adjusting the brake lever? Depending on how bad it is, you can adjust the pushrod and bring the pedal up a little. Hopefully you only have to adjust it a little so it's not akward to get your foot on
Old Feb 15, 2017 | 01:16 AM
RocklandTroy
1st Gear
Yeah I was messing with it and decided to adjust the push rod. I loosened it up quite a bit. It doesn't hit anymore I'm just worried about how far I had to loosen it up
Smogbob
Feb 26, 2021 01:34 PM
Redlegvzv
Apr 24, 2020 04:59 PM
rydahog
Jan 14, 2018 04:22 AM
rjo3491
Aug 24, 2014 07:26 AM
panamoncreel
Jul 8, 2008 01:13 AM
