Vacuum Petcock 2000 dyna wide
Old Feb 18, 2017 | 11:02 AM
fxdx1985's Avatar
fxdx1985
Listen to these guys. Pet your ****, get a Pinge, put a cap on your barbl and ditch the vacuum for a hot chick.
Old Feb 18, 2017 | 11:21 AM
cggorman's Avatar
cggorman
I've got all hard wood. No need for a vacuum.
Old Feb 18, 2017 | 11:26 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by cggorman
I've got all hard wood...
Old Feb 18, 2017 | 11:44 AM
F86's Avatar
F86
Sounds like you're back up and running...
Old Feb 18, 2017 | 12:47 PM
cggorman's Avatar
cggorman
Don't make me show you my wood!
Old Feb 18, 2017 | 12:49 PM
cggorman's Avatar
cggorman
Well...running...but not well... Still have a long way to go. The 5lb weight restriction is holding me back.
Old Feb 19, 2017 | 10:38 AM
skinman13's Avatar
skinman13
Personally, I would eliminate the vacuum line altogether, and replace the petcock with one of these: http://www.pingelonline.com/Fuel-Val...et-reserve.asp
the upside to this is no vacuum leaks or failed diaphragms to worry about...the downside is if it falls over it will leak gas...
Old Feb 19, 2017 | 10:46 AM
Jackie Paper's Avatar
Jackie Paper
That can be remote. However, on older bikes that sit and then are brought back to like in the spring, sometime have a nasty habit of getting trash under the needle valve and poring gas out the vent hose. That is why they should never be just taken off to save a few dollars.
It's just to easy to get distracted and forget to shut off the fuel. Your bike sitting in the hot sun on a city street surrounded by a big puddle of gas could be tragic.
There is just no reason to make a terrorist out of your bike.
JakePie
May 15, 2019 09:01 PM
Jdwy
Apr 30, 2019 05:46 PM
mbeall777
Carburetor Related
Jun 23, 2017 11:39 AM
02EGlide
Exhaust System Topics
Apr 17, 2012 11:46 PM
Good ol boy
Jul 23, 2011 09:02 PM
