2006 FXDBI - Testing Run / Stop Switch - HELP
Old Mar 9, 2017 | 10:01 AM
JustinKase's Avatar
JustinKase
2nd Gear
Default 2006 FXDBI - Testing Run / Stop Switch - HELP
Hey Guys!
I've been a lurker on this forum, but this will be my first post. I hope I'm posting the correct place. If not, please point me in the right direction. I also hope this probable hasn't been posted 1000X times. I did use the search function and didn't find what I was looking for.
I have a 2006 FXDBI that I'm building. It was pretty stripped down when I got it and had been sitting for 3+ years. I put new sheet metal, bars, bar controls, lights, shocks, forks, wheels and other misc parts, but the engine and wiring was intact for the most part, excepts for bar controls and plug and play lights.
My issue is i'm not getting spark. All lights, turn signals, etc work. It will turn over, but isn't getting spark. I have tested the coil with a ohmmeter and it seems to have good resistance. I have checked all the fuses and also the continuity of the spark plug cables and all that looks okay.
My guess at this point is that possibly that the run / stop kill switch isn't engaging in the "Run" position. Does anyone know if there is a way to test its working correctly using a multimeter or test light? or any other way?
Thank you in advance for any help you can provide.
Mjd99
Electrical/Lighting/Alarm
Jun 15, 2017 09:19 AM
JustinKase
Mar 9, 2017 03:10 PM
joshEyeti
Jun 2, 2015 06:21 PM
guyfromgreenwood
Jul 17, 2012 05:23 PM
Murphy's Law
Jul 28, 2011 05:33 AM
