Rec's on cams
miss far as suggestions go, I'd stick with HD because that's my preference, however there are a lot of good cams out there like woods, s&s, and many others.
Im running screamin eagle 259e cams and I love em, however I have a 117 big bore. Even with a 103 the 259e is a good choice.
Anyway tell all us more about your bike, riding style, performance plans, etc and maybe we can help
anyone have experience with this cam?
Since the 57H install, I notice I'm running a little higher revs now to be right at the beginning of the power curve for the engine. Stage 1 was mostly cruising in the 2.5k+ rpm range. Now closer to 3k rpm.
Do you have the shop manual? If you don't, get it. Also, fellow member robbyville gave a great write up on his cam installation. Actually, I'm running his Andrews 57H cams since he went to a different cam later on. Assuming you're also running a high flow air cleaner and non stock exhaust. If you don't have one, get a good ECM tuner. I'm currently running the V&H FP3, and while it's good for Stage 1 applications, I'm not sold on it as a Stage II + tuner. Later this spring (when funds become available), I'm looking at either a Power Vision or TTS-Mastertune.
Lastly, you will be able to use your oil pump and stock parts, however, FOLLOW THE MANUAL for reinstallation of the oil pump. I didn't and I had to purchase a new cam plate and oil pump. $400 that was not budgeted.
