Wheel spacer HELP!
Old Mar 18, 2017 | 02:43 PM
jqb12's Avatar
jqb12
Default Wheel spacer HELP!
Installed the HH conversion kit onto my 12 SB. Everything seemed to go together great, but as I buttoned it all up, I can see that the rotor is not sitting in the middle of the caliper (pic), and I get a strange noise when I squeeze in the brake. So, how should I proceed? Can I just try to insert a
thin washer between the lower leg and spacer to bump it over?
Thanks
Old Mar 18, 2017 | 05:44 PM
Nickd2689's Avatar
Nickd2689
Well first of all, what kind of strange noise? Not to insult your intelligence, but it is normal to hear a buzzing type sound. No offense if you've been riding Harleys for a while, I only mentioned this cause so many people don't seem to know this. Lol off topic but a coworker recently asked my to fix his sportster cause it makes a clunk noise when he downshifts lol.
Old Mar 18, 2017 | 05:53 PM
cggorman's Avatar
cggorman
Wheel (hub) going the right direction?
Any other mods made?
Old Mar 18, 2017 | 06:41 PM
jqb12's Avatar
jqb12
I just bolted the new rotor spacer on and then the rotor, then re-installed. I loosened everything up, played around with the tubes, and it seems to better. I just need to ride it and see if it's cool. Cold and rain in N'east Ohio. Also, I'm assuming both of the spacers with that kit are identical, they weren't marked L or R, and visually looked the same.
Old Mar 18, 2017 | 06:45 PM
cggorman's Avatar
cggorman
I'm not familiar with that hub but don't assume anything. It may or may not be symmetrical. Measure the spacers to be certain. Were there instructions included in the kit?
I'm sure Multihdrdr already knows exactly what's going on.
Old Mar 18, 2017 | 07:57 PM
jqb12's Avatar
jqb12
No instructions, so I don't think it mattered which spacer goes where. Looked like 1 5/8ths. I used the stock SB hub laced to a 21 inch rim. Maybe the tubes weren't exactly straight?
Old Mar 18, 2017 | 08:05 PM
cggorman's Avatar
cggorman
Unfortunately I don't have a definitive answer to explain your problem, but measurements don't lie. If it were mine, I'd take it all apart and measure everything carefully. Rim offset, bearing face offset, rotor mounting face offset, spacer thicknesses, etc. It's entirely possible the kit has the wrong spacers for your application. There a lot of variable that a kit may not accommodate. I would trust my results before any kit contents.
Old Mar 18, 2017 | 08:35 PM
jqb12's Avatar
jqb12
I actually got it looking more centered (not exactly sure how!) the wheel spins fine. Again, once the damn weather cooperates, I can take it out. Thanks for the help
Old Mar 19, 2017 | 08:36 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by jqb12
... Also, I'm assuming both of the spacers with that kit are identical, they weren't marked L or R, and visually looked the same.
No instructions, so I don't think it mattered which spacer goes where. Looked like 1 5/8ths...
Assuming you're still using your mid-glide sliders...
Yes, on your 2008-later Dyna (WG conversion), L & R spacers should be same length...just a little over that 1-5/8
If the rotor is not centered in the caliper, maybe the rotor spacer width is incorrect. Did you measure that?
Old Mar 19, 2017 | 08:54 AM
roadkillvespa's Avatar
roadkillvespa
The front spacers on my 2007 Street Bob are slightly different lengths so are not interchangeable,they are not marked either.
