Wheel spacer HELP!
Old Mar 19, 2017 | 09:03 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by roadkillvespa
The front spacers on my 2007 Street Bob are slightly different lengths so are not interchangeable,they are not marked either.
You have a 2007...Apples and Oranges
Old Mar 20, 2017 | 11:40 AM
jmeiers's Avatar
jmeiers
Maybe whoever laced your hub did not get it completely centered?
What is that sandwiched between your hub and rotor spacer? Looks like a thin washer? Don't remember that on my HH conversion.
Old Mar 21, 2017 | 08:44 AM
jqb12's Avatar
jqb12
There is nothing between those 2. It's simply the rotor spacer up against the hub.
Old Mar 23, 2017 | 04:27 AM
==ShaDoW=='s Avatar
==ShaDoW==
After i put custom wheels on my 2010 wideglide i had to mill the brake pad mounting point to recenter the disc you may have to do that here as well. But I am no expert.
Old Mar 23, 2017 | 05:28 AM
blueangel73's Avatar
blueangel73
Did you put the rotor spacer on the same side of the hub that the rotor was originally on? I know the hub on the street bob has the ability to mount the rotor to both side and if it wasn't mounted to the primary side of the hub, maybe the wheel is off center do to the primary bearing being on the wrong side of the bike now.
Are the axle spacers the same length, maybe one is slightly longer then the other and if that is the case, I would think the longer one would move the wheel more to the right (as you sit on it) placing the rotor more to the center of the caliper.
Whom ever built and trued the wheel would not change this, your hub is aligned via the bearing installation process and the axle spacers you use, once that is established, the truing just centers the hoop to its needed location to be center on the bike.
Old Mar 23, 2017 | 09:17 AM
jqb12's Avatar
jqb12
I think the spacers from Hawg Halters may have been slightly off. I just shimmed the wheel over with a very narrow spacer and the rotor is now exactly riding in the center of the caliper. Thanks for the help.
huskytamer
Aug 18, 2014 11:10 AM
fistbump
Jun 18, 2012 11:37 PM
MizNitch
Sep 11, 2011 04:44 PM
RG462
Oct 23, 2010 07:30 AM
douglas07UC
Wheels/Tires
Jan 2, 2010 07:29 PM
