Bleeding Front brakes Help
Old Mar 20, 2017 | 08:34 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by Nickd2689
Never thought of the whole injecting fluid into the calipers. That's ****in innovative. Good idea whoever thought of it.
I think it was a guy named "Bob"
Also FWIW, his 2001 is DOT5...not caustic
Old Mar 20, 2017 | 11:06 AM
archergodwin's Avatar
archergodwin
Originally Posted by Johnnyh14
Go to Harbor Freight and pick up a Mityvac for $40. It's worth it.
Best money spent...
Old Mar 20, 2017 | 11:12 AM
OddJack's Avatar
OddJack
Great simple tool I have used on my car and bike
Amazon Amazon
Old Mar 20, 2017 | 06:45 PM
skinman13's Avatar
skinman13
I had this same problem the first time I rebuilt my front system from the master cylinder down to the caliper. New parts, cleaned, blown out, and for the life of me I just could not get it to bleed. I have done a lot of automotive and airplane brake systems and I tried EVERY trick I knew! Vacuum pump, oil can, syringe, and some things I just thought up in desperation. Nothing worked. I got so frustrated that I just walked away from the bike for a few days and worked on other things before coming back to the brakes. I had read about bleeding from the top down, loosen up the banjo bolt and bleed the master, loosen the lower banjo bolt and bleed the line, and finally, bleed the caliper. Tap on the caliper while bleeding to move the bubbles out. That worked like a charm, done and done in a few minutes. After HOURS of getting nowhere, it just bleed like it is supposed to.
I also read an article about DoT 5 trapping microscopic air bubbles that are difficult to bleed and the trick is letting it set while those bubbles collect into bigger bubbles that are easier to bleed. Well, I did let it sit for a few days, and folks here have had success with tying back the brake lever and letting it sit overnight before trying to bleed.
I have bled the system using the top-down method a couple of times with good results...just be sure to keep a rag handy.
Old Mar 20, 2017 | 09:21 PM
TexasScooterTrash's Avatar
TexasScooterTrash
skinman13 has the right idea. However, IF all else fails - after all bleeding attempts are done and you are out of beer, pump the lever till it gets as firm as it can. Then hold the lever in to keep the pressure built up and tie it off. Leave it over night and untie in the morning. Check the fluid level in the master, put the cover back on and try it out. You WILL have brakes in the morning.
Old Mar 20, 2017 | 09:37 PM
AFblacksheep's Avatar
AFblacksheep
Mityvac well worth the money makes quick work of bleeding.
Old Mar 21, 2017 | 09:27 AM
Feileod's Avatar
Feileod
I have vacuum bled, gravity bled, hand pumped.....The best results I have had are to make sure you have fluid coming out of the caliper bleeder and then close it, compress the brake lever with a zip tie, (leave a little play so you can remove it later) and walk away. I have had some that were good in a couple of hours and some over night. No mess, no fuss, and has worked every time.
wag_oh_neer
EVO
13
May 21, 2017 05:51 PM
Pgh-mike
EVO
Jun 1, 2016 06:38 AM
Biggzie
May 28, 2016 09:03 PM
groundpounder rob
Aug 14, 2013 11:04 AM
johnk
Oct 5, 2006 01:47 AM
