Alarm problem
Old Apr 8, 2017 | 07:02 AM
grimsmith's Avatar
grimsmith
Stage II
Angry Alarm problem
I've had my 2012 Wide Glide laid up a few months and now I have to enter the pin every time I try to start it. Otherwise the alarm sets off. I tried renewing the fob batteries but it won't play. It starts OK if I switch on and enter the pin and occasionally I see the message on the display: 'No Fob' while I'm riding it. Any ideas appreciated.
Old Apr 8, 2017 | 07:20 AM
cvaria's Avatar
cvaria
antenna/wires may have come loose. Or fobs need to be paired again.. the antenna rests under the set. Take a look at the connections...
(working)
https://serviceinfo.harley-davidson....ocument/131759
look for this guy:
the dealer probably will not charge you to pair/re-pair your fobs
Old Apr 8, 2017 | 11:08 AM
joe.1955's Avatar
joe.1955
Check the easy stuff first. Make sure the battery is not upside down in the fob.
Old Apr 8, 2017 | 04:44 PM
Smogbob's Avatar
Smogbob
You can also pull the main fuse out, and put the main fuse in again this resets the fobs, cannot see why they would need pairing again, I have left battery out of my ride many times over winter, never had a problem, except when battery in Fob was toast.
NCHD
2014-2024 Touring Models
47
Apr 5, 2020 09:26 AM
13_Lucky
Mar 9, 2014 04:26 PM
hevis1
May 2, 2013 08:05 PM
hdfun123
Mar 2, 2011 04:15 PM
JiminyKrikit
Feb 8, 2010 05:35 AM
