Dual disc w/ custom lines?
Old Apr 8, 2017 | 10:26 PM
cggorman's Avatar
cggorman
Default Dual disc w/ custom lines?
Those of you have done custom dual disc lines, how did you handle the tee? I'm starting to research the parts needed for my conversion and there are a lot of ways to handle the line split.
Curious to see what y'all did, how you like it, & if you would change anything.
I must say I'm not real interested in some semi-custom "+/- X inches" pre-assembled type of line or kit. I really want to dig in and make it my own.
Old Apr 8, 2017 | 11:21 PM
Clsd350's Avatar
Clsd350
Summit racing has all you need. Will take some time finding all the pn# a -4 tee is all you need do split the line on a non abs. Not sure what entailed if you have a Abs?
Old Apr 8, 2017 | 11:32 PM
cggorman's Avatar
cggorman
So, you're using flare fittings and a standard flare tee? How did you fasten the tee to the tree? A "P" clamp?
Old Apr 8, 2017 | 11:42 PM
cvaria's Avatar
cvaria
https://spieglerusa.com/brakes/brake...ake-lines.html
pink lines.... cus you can.
they'll do whatever you want.
my lines have been goodridge all three times and the tee was flared.
the tees have a screw hole for the trees
Old Apr 9, 2017 | 12:21 AM
Nemosengineer's Avatar
Nemosengineer
Goodridge tee with minor machine work retained by a 17-4PH shoulder bolt, Earls -3 Speedflex hose and fittings, hose assembly at home.
: Mike
Old Apr 9, 2017 | 12:27 AM
cggorman's Avatar
cggorman
Mike, that's one of the tees/splitters I was considering. Thanks for the pic. Gives me a better idea of the size.
what size lines? 3?
Wide or Mid trees?
Goodridge banjos?
How did it bleed? I've never done a dual/stacked banjo setup. Seems like it would hold on to air.
Old Apr 9, 2017 | 12:31 AM
cggorman's Avatar
cggorman
I've been leaning real heavy toward Goodridge. I have good experiences with their pre-fab lines.
That's one of the other tees I was considering but wasn't.sure what fittings it took. I think inverted flare knocks it out of the running, unfortunately.
Old Apr 9, 2017 | 12:43 AM
Nemosengineer
what size lines? 3?
Wide or Mid trees?
Goodridge banjos?
-3 lines and banjos from Earls plumbing. https://www.holley.com/brands/earls/...nd_speed-flex/
Mid trees.
Stahlbus bleeder's and their vacuum bleeder bottle thing, the brakes bleed from dry to rock solid in under 30 minutes from start to finish. I was stunned I thought I would be bleeding for days, the last time I bleed a double banjo setup from dry it took hours.
: Mike
Old Apr 9, 2017 | 12:45 AM
TwiZted Biker's Avatar
TwiZted Biker
Any good sized aftermarket parts catalog like Custom Chrome or Drag Specialties will have extensive selections of both ready made kits and customizable brake line components by a couple brand names. I make up all my lines, don't think I've ever used a ready made factory replacement.
These guys have some trick stuff and will make to your specs is wanted.
https://spieglerusa.com/brakes/brake...line-kits.html
Some of my builders stash,
Old Apr 9, 2017 | 01:05 AM
Nemosengineer
Chris,
Some stuff I forgot to add... Earls and Goodridge banjos are a different width than factory and you must use the matching bolts, verify the banjo width before you buy anyone's banjos as all the aftermarket manufactures screw with the width so you have to buy there bolts, this is critical for double banjos.
: Mike
