Cross Reference
Old Apr 20, 2017 | 09:13 PM
ARider4life's Avatar
ARider4life
2nd Gear
Default Cross Reference
Hello Everyone,
I am new to this forum, 1st time asking a question here, I have a 1999 FXDX, the speedometer and tach just shorted out and I found one I think might work, it is from a 2000 XL1200S, does anyone know if this will work?
Old Apr 20, 2017 | 10:01 PM
bl_dg's Avatar
bl_dg
Hard to say. The part numbers are different. Even the 2000 FXDX uses a different part number than the 1999. (Google Ronnies Harley Davidson and use their microfiche parts finder.)
Maybe someone else has more info.
Old Apr 20, 2017 | 11:23 PM
ARider4life
2nd Gear
Thank you for the Ronnies part search! I will use it and see just order a new set, if they stock it.
Old Apr 21, 2017 | 11:11 AM
canyoncritter's Avatar
canyoncritter
Look for the wiring diagrams, they are out there on the net I've found them before. Put a 99 set on a 02 had to re pin some the wiring for the tach. Turnsignals would make the tach light flash and the needle wave/sweep. Never messed with the speedo side,just did math.
mfalbo1978
Jul 11, 2018 05:43 PM
clidem64
Sep 5, 2017 11:29 AM
FXDL32966
Jun 26, 2017 04:17 PM
XTsHOG
May 12, 2013 01:28 PM
hawg50
Feb 2, 2010 02:00 PM
