se 2 pipes on an 07 fxd
Old Jun 4, 2007 | 08:18 PM
ffsaulshd's Avatar
ffsaulshd
Default se 2 pipes on an 07 fxd
will se 2 slipons work on an 07 fxd? will the bike adjust to the change without any other adjustments?
Old Jun 4, 2007 | 10:12 PM
thrillseeker's Avatar
thrillseeker
Default RE: se 2 pipes on an 07 fxd
bigger question would be if the bracket mounts are the same. they stopped selling the SE II's over a year ago.
I don't know how much compensating the O2 sensors will make. The SE II's will have greater flow than the SE's you can buy now.
my guess is that even with the EMC and O2 sensors, on the '07's designed to automatically compensate, is that the bike will still be lean cuz the factory has certain limits on what it can do (EPA stuff ya know).... soooo, what I'm saying here is you probably would want to consider the PCIII or other device.
Old Jun 4, 2007 | 10:22 PM
Trotter's Avatar
Trotter
They work on the 06's... If your not doing the A/C you should be OK . Or get the Stage 1 Race download if your gona do the A/C... andkeep a eye onyour plugs.. Ethenol makes if kinda hard to readNow.....
sparky_mo
Oct 19, 2011 04:04 PM
rewog
Jan 4, 2009 11:42 PM
bubbas1
Great Lakes
May 18, 2007 05:55 PM
rockstar_josh
Apr 26, 2007 05:21 PM
03WG
Dec 23, 2006 12:29 PM
