Went to Home Depot and bought a chrome cabinet pull. Drilled it out and tapped it to 1/4" and then epoxied a 3/4" long stud in it. $2.65 for a new chrome seat screw. It also serves as a bungee hook point.
A tube of clear silicone sealer and a 4 wheeler GPS. I took a Garmin 1490T a part liberally used the sealer around all internal edges and the power connector. Used a part of the clear packaging to make a internal cover for the speaker port. After dumping a quart of water on it there was some water between the layers of the screen but it still worked fine so we will call it water resistant for now.
Thinking of masking the screen and shooting a couple of coats of clear coat might fix any addition seepage.
Did you horn sound loud enough without any rubber grommet on the mount ?
I relocated mine to the front A frame (Lenale kit) and without a big rubber grommet it would not work, and even with rubber it doesn't seem quite as loud. Maybe cause I left the cowbell cover off.
