07 SE slip-ons - HELP!
Old Jun 5, 2007 | 01:01 AM
SurfGuitar's Avatar
SurfGuitar
Default 07 SE slip-ons - HELP!
When I picked up my new SB, my salesman talked me into getting the "new" (quiet) Screamin' Eagle slip-ons. At the time, I was unaware that these mufflers had been redesigned to be DOT noise compliant. That is an understatement...I can barely tell the difference from the stock mufflers. If I had it to do over, that is $300 I would have spent elsewhere.
While I'm not looking for an obnoxiously loud exhaust note, I would like the bike to sound like a Harley. This is my sixth one, andthe exhaust note is way too quiet. Interestingly, my brother just bought a new 1200L Sporty, and his '07 SE slip-ons sound fantastic and are plenty throaty. Probably because the Sporty SE'sare much shorter than the Dyna ones. My last bike had a pair of Samson fishtail slip-onswith internal baffles, and they sounded awesome.
I know the best solution is to 86 the SE's and get some V&H or Rush slip-ons, but before I do that, I'm considering removing the fiberglass packing from the SE baffles. I did a search and found some threads that address this, but no one really stated how the bike sounded after this was done. If anyone has done this mod, or has a better idea, I'm all ears. At this point my air cleaner is stock, as is the ECM. The bike does run great with the SE's, no popping or flat spots, it just doesn't sound "right". Any input will be appreciated!
Old Jun 5, 2007 | 05:58 AM
TOMMAY's Avatar
TOMMAY
Default RE: 07 SE slip-ons - HELP!
I imagine you could get some Big City Thunder baffles that would take care of that problem.
Good Luck
Tom
Old Jun 5, 2007 | 06:27 AM
moonsfmc's Avatar
moonsfmc
I took the wrap off my baffles and it made it alittle louder but not to bad sounds alittle deeper.
Old Jun 5, 2007 | 08:36 AM
Bobberforever's Avatar
Bobberforever
This is what I've done to my quiet Screamin' Eagle 07slip-ons :
http://img509.imageshack.us/my.php?i...gle2007qk3.jpg
First, remove the 2 littles screws:
http://img249.imageshack.us/my.php?i...boulonsgs9.jpg
Then I used a wood stick, that fitted into the baffle and slam it on the ground several times to remove the baffle:
http://img249.imageshack.us/my.php?i...bafflesti0.jpg
Here is the baffle :
http://img521.imageshack.us/my.php?i...ledmontmj9.jpg
I drilled holes in the baffle (10mm is about half an inch):
http://img521.imageshack.us/my.php?i...met10mmhb5.jpg
Closer:
Some new holes under :
http://img521.imageshack.us/my.php?i...entairefh8.jpg
I removed a little bit of fiberglass too. The most difficult part of it, is to aligned the littles holes for the 2 screws. I used sand paper to smooth the edge of the baffle to make it fit easier into the muffler. Another trick is to enlarge the 2 little holes for the screws on the baffle, It help when you put it back and they are not 100% aligned. I used a rubber hammer to knock the baffles back.
Here in Canada, cops are severe on loud pipes so this mod is just perfect for me. The sound is a little more quiet than the old SE slip ons but it's a lot better than stock 07 SE slip-ons. Another good point: it is written, on the pipes, that they are "street legal"
Old Jun 5, 2007 | 03:59 PM
SurfGuitar's Avatar
SurfGuitar
Thanks for the advice, guys. I just finished removing the fiberglass packing and reinstalled the mufflers to see what it sounded like before drilling any additional holes. It sounds just the way it should have all along...the glass packing was the culprit.
My brother rode the bike up the street, and I could hear it a quarter mile away, so I think I'll leave well enough alone. The tone is nice and deep, but not too "over the top" for my aged ears.
Again, thanks for the help. This is a great forum!
Old Jun 5, 2007 | 04:40 PM
toprofile's Avatar
toprofile
Sounds like something I'd be willing to tackle.
Thanks for takingthe time to image and document your steps so well !!
on the same basis - is there any another baffle that is designed as a direct replacement for these SE slip-ons? Saw a mention of "Big City Thunder". Are they direct replacements for these baffles??
Any others??
Old Jun 5, 2007 | 05:10 PM
twiceretired's Avatar
twiceretired
Quick question on altering these mufflers. Does anyone have any experience with measuring, or just 'feeling', any increase in flow? I understand that the new SEII's have no more flow than stock. Does this mod help here too? Thanks, Frank
Old Jun 5, 2007 | 06:15 PM
Shrug's Avatar
Shrug
ORIGINAL: toprofile
Any others??
BCT baffles are a direct replacement for SE-II Slip-On baffles. Only takes a few minutes to swap 'em out. You'll love the sound!
SurfGuitar's Avatar
SurfGuitar
I checked the Big City Thunder site, and their baffles apparently fit the 2006 and earlier SEII slip-ons.
Regarding the flow of the new SE's vs. the SEII's, I don't know the answer. However, I wanted to retain the stock air cleaner and ECM map, and the 07 SE's allow you to do that. A remap is required if you go with a free flowing exhaust and/or a more open air cleaner. The stock map likes a good amount of back pressure to boost low-end torque. I'm sure that comes at the expense of top end power, but I'm no longer the speed freak I was when I was younger.
Pulling and reinstalling the baffles on the SE mufflers is no fun, especially the reinstall. It took some grinding and some really foul language to get them back in place. I used rivets instead of the original baffle retaining bolts for a cleaner look. And drilling the baffle retaining holes to 1/4" was a huge help. Thanks to Bobberforever for that tip!
While I am now satisfied with the sound of the 07 SE's, if I had it to do over I'dhave gottenthe Rush slip-ons with 1.75" baffles. They will work with the stock mapaccording to two dealer service reps I've talked to, as long as the air cleaner left stock.
Old Jun 6, 2007 | 09:12 AM
Bobberforever
I dit not remove all the fiberglass, my dealer told me that the slip-ons may turn yellow because of the heat. Anybody heard about this problem ? If it is not true, I will remove it all ! What do you think ?
