Couple of questions.
What bike are you talking about and what kind of mods does it have?
Why did you replace the regulator? Was it diagnosed as no good?
If the CE light comes on there's a fault code. Pull up the code.
All Right. So I went to Youtube and saw the video, followed the instructions.
On my odometer it comes up: do1clr. After I push the reset it comes up: do2clr. This happens through to the # 10. The it comes up PPU. Then back to 1 again.
Videos and pictures are cool and they do help, but sometimes is good to "read" some of the other links.
(if you can)
Did they have something like the "No Child Left Behind Act" in Canada too?
There's usually a reason that the voltage regulator goes out... and it's usually not the voltage regulator... it's either upstream (alternator) or downstream (battery/connections).
Regulator going out to me means you have not found the root cause yet.
My alternator went out, took out my voltage regulator and my battery.. course, battery was 7hrs old and needed replacing anyway... but, non the less... it finished it.
