Too restrictive intake?
Old Apr 30, 2017 | 08:46 PM
therick04pp's Avatar
therick04pp
Default Too restrictive intake?
Hi all,
I recently purchased a DK custom 587 intake kit. The filter element is a K&N and came well oiled (red). Install was a breeze and there were no issues.
Now, after about 150 miles, the filter is almost white, slight tinge of pink. It has not been exposed to water or rain. So I am thinking that maybe my bike has sucked the oil out of the element meaning that it is too restrictive and maybe I need a larger intake?
Thoughts? Do you think the DK 636v would be enough?
Old Apr 30, 2017 | 09:19 PM
rkoivisto's Avatar
rkoivisto
I think you are over thinking it.
The color of the filter doesn't have anything to do with the restrictiveness of it or that you need a larger intake.
Old Apr 30, 2017 | 10:16 PM
therick04pp
I may be over thinking it.. I have heard of it before but never on my own stuff. If the intake is sucking more air in, than the filter can efficiently provide, it will increase the vacuum in the filter chamber and suck the oil from the media. I didnt mean a larger intake, I meant a larger air filter, my mistake.
I have had a K&N in my truck for over two years and it is still as red as the day I bought it. I cant think of any other reason why the red oil, that is soaked into the element, is no longer there. The unit I took off was a dry element, larger, but ugly and had the stock oil breathers so I changed it to this one with a smaller, wet element. A friend of mine has the larger 606 and has had it since first ride, last year and it is still red like mine was 150 miles ago...
Old Apr 30, 2017 | 10:26 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Depends on "where" the restriction is.
Follow me on this.
A "more narrow" intake path will force the incoming air to increase in velocity. This increase promotes add'l torque in the low to midrange of the rpm scale.
The bad part? That "narrow pathway" virtually strangles the engine in the upper rpm range.
This is why dyno operators give about 75-85% throttle from the beginning of the pull to just before midrange in the rpm. They then go WFO to the redline. It makes for a better hp#.
Now, if the intake restriction is at the filter, then you might need a more efficient filter.
And no, we didn't even get into airbox size/shape or "high pressure" zones...
Old Apr 30, 2017 | 10:30 PM
canyoncritter's Avatar
canyoncritter
Someone licked the red off?
Old May 1, 2017 | 01:03 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
In another 150-200 miles it will have changed over to a light grayish color. That's what they do and they're still working as they should. No need to worry.
Old May 1, 2017 | 06:00 AM
Mchad's Avatar
Mchad
The red dye in the oil fades when exposed to daylight. The red oil in your car filter is hidden and not exposed to daylight. The oil remains, only the color fades. Happens to every exposed K&N I have ever had. Called K&N about it a few years ago and this is what they told me. No worries.
Old May 1, 2017 | 01:57 PM
therick04pp
That makes sense, thank you both.
Old May 1, 2017 | 07:35 PM
TUCCI's Avatar
TUCCI
Huhh didnt know that.
Zack DeMott
General Topics/Tech Tips
Apr 22, 2019 03:39 PM
jcanrun
Jun 5, 2017 05:04 PM
Transporter
Sep 16, 2013 08:27 PM
Bigwillie
May 26, 2009 01:07 PM
Ram
Jan 27, 2006 01:54 AM
