Switch Back Wheels
Old May 21, 2017 | 05:33 PM
fabman's Avatar
fabman
6th Gear
Default Switch Back Wheels
Hi all, I bought a set front & rear wheels off a Switchback. Want to pot them on my 96 Low-rider. I know they are off the 51mm front end, and mine is just a 39mm. Any Ideas on how to make em work, front and rear? Or do I need to get a Switchback front end (which I really wouldn't mind). Also would I have to widen my swing arm? Any help ya'll can send my way would be appreciated. Thanks Ahead...
Skid...ZFFZ...
Old May 21, 2017 | 05:47 PM
cggorman's Avatar
cggorman
I don't have exact answers but you've got a hill to climb.
At a minimum you have different axles, bearings, axle spacers, front rotor diameter and maybe rotor offset, a narrower rear end, and wider pulley. Don't know for sure about rear rotor and pulley mounting differences. There may be more.
I believe the FLD has wide glide front fork spacing. Not sure about EVO Low Rider, but I thought they were narrower (either mid- or narrow glide)
I also believe the widest you can go in the rear (without frame mods) is 150mm.
I'd suggest you start looking at vulcanworks.net for adapters and spacers after taking careful measurements comparing your stock/current wheels and the FLD's.
Hopefully Multihdrdr sees this and has better info.
ThaGlyde
Stock Harley Take Offs
Sep 28, 2018 06:55 AM
varider12$
2014-2024 Touring Models
14
Jun 15, 2017 04:52 PM
Olmy207
Mar 23, 2017 10:48 AM
Neggy ZRXOA 5248
Nov 30, 2010 08:08 PM
