Top Motor Mounts/Stabilizer Links
While my motor is apart, I would like to replace the top link. Here's my old OEM link and the Custom Cycle Engineering link I've been using... Are there other top link options I should consider? The CCE piece is a little funky, and I don't think I want to reuse it. I feel like it allows too much movement in it's quest to isolate the rider from vibration... My old OEM link is just... old. The rubber in the ends is all cracked and shrunken, etc. Of course I can get a new OEM unit, but thought I would check on other options first...
Next question: I would consider replacing the whole mounting bracket, if I found one that really looked nice... Why does every aftermarket one I find have the vertical tab that looks like it would bolt straight to the frame? Is this how Softails work? I've seen several that are listed for my bike, like this one from Vulcan, that have this vertical tab... Maybe it can be unbolted, but none of the pictures show the other side (I've emailed Vulcan with the same question, but haven't yet heard). Vulcan offers coil brackets for these mounts, but not horn brackets... So I would have to fabricate something if I wanted to keep everything in the same place...
Or maybe I'll just powdercoat my original piece. Just looking for options...
One option is to replace the OEM top adjustable link with a true heim link, if you look at the factory link it is rubber lined with spacers pressed in. I replaced mine with with a heim end link (I ordered my link from Alan Sputhe, Its the same link used on the Positrac chassis kit), primarily because I felt it would add a bit of stiffness and hold the chassis alingment better than the rubber lined link. I have the full Positrac kit on my Dyna along with the upper link, it does vibrate a bit more than stock, but the vibration is at the same engine speed as stock, it's not objectionable at all, still dead smooth at highway speeds.
The CCE link shown in your photos, personally I would not reuse it, as you have noted, it's a flexi-flyer...
The solid mount engine bracket with the tab cannot be used as it's a Softail part, I am not aware of a aftermarket mount for the Dyna, but I never searched for one.
: Mike
Wait...The stock link isn't Heim jointed? I'm like 95% sure mine is.... I need to look tonight.
: Mike
I was leaning towards a new OEM unit, but I really like what you've done with the Sputhe link. I don't really care if a few more vibes reach me at certain parts of the rev range, as long as I know they aren't generated by something problematic. Since I'm in email contact with Sputhe now about a rear stabilizer, I'll inquire about a link as well. Did you have to modify it at all, or did the length allow for an appropriate range of adjustment?
Thanks for the idea!
Glad this came up. Thanks! I'm off to get the real deal! (And save more weight!)
Oh, on my 99, it's 3/8 studs/bolts and the center-to-center on mine is 4.635". I didn't break loose the lock nut to check adjustment range, but I'd think 4.625 sounds like nominal (guess) so 1/4" on either side should be sufficient for alignment purposes.
...and just how do you have a nephew who's a monkey? Your family must have some stories...
I think I'll just assemble one myself!
