mid controls
Old Jun 1, 2017 | 01:04 AM
ecervantes82's Avatar
ecervantes82
Stage III
Default mid controls
hey guys, I recently switched from forward controls to mids. after riding for about an hour, I looked down to see I was leaking oil from the shifter shaft hole on my primary. any ideas on why it would be leaking? it isn't a lot of oil, it kind of looks like excess is draining from the hole............nevermind guys, please do not reply to this thread. I found the answers I needed on an older one.
Old Jun 1, 2017 | 02:03 AM
sparkalot's Avatar
sparkalot
Greetings from Claremont! Have you ridden to Mount Baldy Village yet?
I changed from mid controls to forwards, but left the cross shaft in place (crosses thru the inside of the primary) without cutting it off ....anyway, just curious , when you had forward controls what was covering the cross shaft, like a cap or anything? What year is your bike? Street Bob?
Old Jun 4, 2017 | 09:36 AM
archergodwin's Avatar
archergodwin
Originally Posted by sparkalot
....when you had forward controls what was covering the cross shaft, like a cap or anything? What year is your bike? Street Bob?
There is a pop in plug for the outer I think... I did it clean by removing the inner primary, and replacing it with a chromed piece off of a softail ( no hole for mids ), then cut a piece of gasket material for the outer's hole, and the aforementioned chrome plug. I may eventually swap my outer for a chrome unit from a WG.
Old Jun 4, 2017 | 10:26 AM
sparkalot's Avatar
sparkalot
Nice bike ! I can see and appreciate the many hours and planning. You must have had a vision of what you wanted and worked towards the vision one mod at a time Very unique motorcycle
Old Jun 4, 2017 | 10:51 AM
petefwa's Avatar
petefwa
Make sure you've got a primary cover gasket for mid mounts, it seals the shaft between the inner and outer primary cases. That's the only place it can leak from memory.
Old Jun 4, 2017 | 11:44 AM
BuckeyeUltra's Avatar
BuckeyeUltra
Check for the same thing happened to me when I retrofit my 09 FXDL... double check you have a "tower gasket" in the correct place.
When I took everything apart it went flying into an oil pan i had below the primary and never knew it was there...until everyrhing leaked after installation.
180Tiger
Jan 27, 2019 07:17 PM
Belson_c
Sep 26, 2017 08:13 PM
rogersachs
Jul 25, 2013 02:11 AM
bosken
Aug 5, 2008 01:33 PM
davidsdad
Jun 9, 2007 10:46 AM
