Received Wrong Predator Mount?
Old Jun 9, 2017 | 12:53 PM
tomt's Avatar
tomt
Originally Posted by Kraken
lol, do it at the same time as an oil change. That video makes it seem a lot harder than it is. If you have the oil filter out of the way it's not that hard at all.
I haven't watched my video in a while. I think I mentioned the install is easier with the filter off. I just did a oil change a few days before I did this install. If I knew I was going to do this, I would have waited.
The actual time it took for the install was about 20 min. I replaced the old mount with the OEM when I did the oil change. I was asked to do this video for their website. When I got the Predator, the whole procedure was still fresh in my mind. Making the video was time consuming.
Believe it or not. I haven't had a chance to really test out this mount. I've been so busy the last few years. I only put 100 or so miles on the bike.
Old Jun 9, 2017 | 03:44 PM
Smogbob's Avatar
Smogbob
Originally Posted by F86
Once the bike is properly positioned, this job only takes about a half hour. I't really very easy. I found the best way was to have the bike fully upright using whatever form of lift/jack/friends you may have, and then position a small scissor jack (possibly from your trunk) under the front of the engine to take weight off the mount itself. After some trial and error, I also found it was best to leave ALL of the bolts a little bit loose, then start the engine. Blip the throttle a little, and then tighten and torque everything with the bike idling. This helps prevent locking the engine into a slightly misaligned position... At least that was my impression...
Cheers for that tip, I normally do it by the service maual, loosen bolts then run engine for 5 seconds, then turn off engine, but leave it idling seems a better idea to me.
Old Jun 9, 2017 | 04:23 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by imboden
How hard is it to put on the bike?
Not very
Couple of jacks..., couple of wrenches..., and two / three beers
Easy one man job
OP
Ya got the right one..., don't overthink it - and start idle the motor before torquing the bolts - that allows the motor to settle and center
Idle..., do not rev - then shut it down and tighten
NOTE
This mount will not fix vibrations - that is unless the current mount bad
It will make the bike corner / turn really.., really well
Ghost
Old Jun 10, 2017 | 12:02 AM
MRFREEZE57's Avatar
MRFREEZE57
install took me about 45 min. is simple if you have a lift, then use a scissor jack under the motor to support it.
Old Jun 10, 2017 | 05:53 AM
Tnbrit's Avatar
Tnbrit
I keep reading that the Predator,dosen't stop/cure/fix,vibrations,which is a bit strange,because that's what it's designed to do,the stability is a by product of the design.
Now if there is no vibration to start with,then i suppose it can't cure it,but that is it's purpose,the clue is in the name of the manufacturer Vibra Technics.
Old Jun 10, 2017 | 08:18 AM
Ghost_13's Avatar
Ghost_13
Side note
At times it seems everyone and their dog has a "vibration" issue round here
So when one speaks of this..., that..., or the other - vibration issue - one has to be real damn specific
Especially if they're looking for us to help diagnosis it
Predator eliminates (or at least significantly reduces) lateral movement
Think of it as sideways vibration..., if that'll help wrap your head around it
Lateral forces want to make the bike go straight..., in a turn..., they also counter act side to side maneuvers - when traveling straight
This mount "neutralizes" the bike's predisposition of fighting these
So when you want to turn - the bike turns...., when you want to maneuver - sideways..., at speed
Bike responds to your input - as opposed to fighting you every damn step of the way
It not a cure all - rather icing..., on a layered approach..., to obtaining a very nice handling..., very responsive - scoot
btw
Never can tell about a name - go figure
Ghost
Old Jun 10, 2017 | 08:38 AM
F86's Avatar
F86
Originally Posted by Ghost_13
Side note
btw
Ghost
Agreed on all counts! And to go a step further... When the lateral movement is not properly controlled, the lower part of the engine can actually pivot against the top mount slightly, like a pendulum. It may be a marginal amount of movement, but when the engine moves laterally, so does the transmission... And the swingarm is mounted in the tranny case... So the rear wheel's vertical alignment can actually shift a little bit due to a poorly located engine. This creates a very disconcerting "rear steer" effect in fast corners, and it allows the rear wheel to try to follow ruts, etc...
So a front engine stabilizer can result in much better handling from the rear wheel overall.
Dynas are interesting... It's not just the engine that's rubber mounted... The whole frame, fork and front wheel are essentially one unit, while the drivetrain, swingarm are rear wheel are another. The two units are pretty much attached to each other with rubber mounts. The desired balance between a rigid structure and a vibration-free ride may be different for different riders... I favor chassis dynamics over engine isolation (at least to a point).
Old Jun 10, 2017 | 09:19 AM
cvaria's Avatar
cvaria
so is there some predator equivalent for the rear? a rubbery true-track?
Old Jun 10, 2017 | 09:25 AM
Rubline's Avatar
Rubline
Ok, the Predator mount is installed but now its raining here in NewYorkaStan. Took just under 2 hrs. Biggest problem I had was getting a small jack under the front center of the motor to relieve the weight. I was able to torque all the bolts because my oil filter is mounted on the left down tube and there is a small cone shaped adapter where the filter used to be. The oem mount was oil soaked and the rubber on one side split almost all the way through. Thanks for all the help but I tend to think the worse when I do something like this.
Old Jun 10, 2017 | 09:28 AM
TinCupChalice's Avatar
TinCupChalice
Sputhe Engineering Positrack rear mount; on my wish list
