Low Rider S noisy primary
Old Jun 19, 2017 | 06:11 AM
Nickd2689's Avatar
Nickd2689
Ams oil super shift.
Old Jun 19, 2017 | 08:30 AM
2k2ss's Avatar
2k2ss
My valve train makes so much noise that I can't hear anything from the primary!! Lol
Old Jun 19, 2017 | 08:34 AM
Nickd2689's Avatar
Nickd2689
Every twin cam I've had has valvetrain that was loud as ****. So tempted to switch to gear drive.
Old Jun 19, 2017 | 10:22 AM
imboden's Avatar
imboden
I use mobile syn3 in all three holes.
Old Jun 20, 2017 | 02:55 PM
Trepifajxl's Avatar
Trepifajxl
6th Gear
Guess I will try 20W50 Motul, or Castrol oil...
Old Jun 20, 2017 | 04:07 PM
Qdog002's Avatar
Qdog002
Try HD Formula +. I believe all 110`s have Syn 3 in all holes but not certain.
Old Jun 20, 2017 | 07:04 PM
Nickd2689's Avatar
Nickd2689
yes, from the factory it has syn 3 in all 3. When I first got my lrs, I asked my parts guy and was told I could switch to formula, but I ride year round and felt synthetic would best suit my needs.
Old Jul 20, 2017 | 02:50 PM
Trepifajxl's Avatar
Trepifajxl
6th Gear
Hello gentlemen.
I have changed oil to Formula plus and was significantly better. I have found three steel chipd on the drain plug, so going to dealer to check.
Old Jul 20, 2017 | 07:57 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The HD primary chain auto tensioner is notorious for over tightening the chain. It's designed to only tighten and does not allow slack in the chain. I have used Mobil1 V-Twin oil in the primary with no problems in with the Hayden tensioner. This oil is 20W-50. A heavier oil will be a little harder on the clutch soaked on a cold morning with heavy oil. Ask the dealer to put the SYN 3 back in if that's what you want. A lot of people are happy with that Formula + primary oil from HD, your call.
Old Jul 20, 2017 | 09:52 PM
MRFREEZE57's Avatar
MRFREEZE57
not sure about all tensioners but when changing primary lube one can poke a screwdriver on the upper section of chain thru the derby cover, mine seems to have about 1/2" movement up and down, seems about right.
