Low Rider S noisy primary
Old Jul 24, 2017 | 08:56 AM
archergodwin's Avatar
archergodwin
About 10k on my Hayden. I've tried all types of oil in the primary.. and have settled with the same oil I put in my engine, Mobil 1 vtwin 20/50.
Synthetics will not muffle engine/valve train noise like a standard fixed grade... and HD Syn3 will make your engine sound like you've got marbles bouncing around in there.
As for the 'metal chunks'... next time you're 'in there'.. pull your clutch pack and take a look at the splines that run next to the primary bearing: 9 will get you 10, you've got fractured splines... the compensator is not the only thing that suffers from an over tight chain.
x51chief
Oct 14, 2013 08:00 AM
triglide1
11
Nov 22, 2010 03:09 AM
FX4
Jul 14, 2010 08:48 PM
dbleagle
Jun 2, 2009 08:54 AM
mac6539
Sep 24, 2008 08:04 AM
