103" power upgrade
Old Jun 28, 2017 | 01:38 PM
Mnapier's Avatar
Mnapier
Stage I
Thumbs up 103" power upgrade
Hi all, I am currently riding a 2016 fatbob, with a stage 1 kit and a set of SE 211 cams. I have been looking to do another power upgrade and was thinking along the line of 110" barrels and high comp pistons. Have any of you's done this or something similar? How'd it go? Will the heads/valves and rest of the engine handle it? Etc. cheers in advance
Old Jun 28, 2017 | 03:15 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Yes you can simply add cubic inches and will feel a notable difference. However, to fully use those cams and pistons you may consider a set of performance heads during the upgrade.
Old Jun 28, 2017 | 11:41 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If you now have a set of 211 cams, you're already up to a "Stage 2", if that's what you choose to call it. If you want to go 110", you'll have to reconfigure almost everything so it all gets along together. Heads, cams, cylinder bore, intake, exhaust, etc, etc, etc. I suggest you do some serious reading on here before deciding to take the plunge.
Old Jun 29, 2017 | 01:47 AM
mmesa005's Avatar
mmesa005
If your bike is still under warranty then you may wish to start at the dealer and look at the various 110 kit packages. One of the nice things that Harley does is give you a projected view of how much performance gain you can expect.
https://www.harley-davidson.com/shop...rformance-kits
StevenTammy
Exhaust System Topics
13
Apr 1, 2014 07:42 PM
papifun
Sep 22, 2013 07:09 PM
Justinp
Sep 1, 2013 06:44 AM
zeta596
Apr 11, 2010 08:05 PM
Ultra61
13
Nov 20, 2007 09:56 AM
