Meant to say tapered like the picture. AS far as the bracket.....mine bolts to the transmission side and then has two holes for the muffler to bolt to it. In the front of the bracket is a separate mount for the rear pipe. Wen my pipes is tightened down it is off of the bracket by less than eighth of an inch. Leave everything loose until you tighten down the exhaust and then move stuff as needed to a happy place. If necessary a screamin eagle style exhaust gasket could be used to give you a little more wiggle room
Well, enough said...or rather not said. I'll be going back to singles. I'd be willing to bet most of you guys running the T Headers have cracks but haven't noticed it yet. Like I said, you have an aluminum motor and steel pipes, so there will always be a lot of heat induced stress where the pipes come together. I also don't follow the idea of 2-1 increasing power, since the firing order is so irregular on these bikes. If you time the pulses for one firing pulse, it would necessarily be off for the opposite firing pulse. Singles can be optimized for the displacement and RPM range desired.
At least that's where I'm coming from.
You're not coming from the right place. Choose to disbelieve fact if you like. I'm sure some short shots will work for you. My AL motor and steel 2:1's have never cracked.
I've got 15k miles on mine. Small crack in the bracket but the pipe is fine aside from the fading and flaking black paint on the front header near the bottom where'd get hit with road debris and water when it rains. I took all of the heat shields off also. Hopefully getting a new reinforced bracket off a dude. I'm probably going to recoat it with Cerakote so I'll double check there's no hidden cracks when I blast it but the paint is so thin I'd almost guarantee it would show up, it's not like it's powdercoat.
Jason, I appreciate the pics. That is the bracket I have and the gaskets I'm using too. Does your bracket hard mount to the pipe? Mine uses a rubber isolator. If you guys are hard mounting, then that may be where my cracks are coming from...vibration from the rubber isolator.
Kraken, (your screen name is a nice pun for my problem!?!) I can usually tell when the pipes are cracked as the engine starts popping on deceleration. When it gets constant, I remove them to find the crack on the inside, invisible until you remove the pipe. I run the bike hard and downshift regularly to stops, so my popping is pronounced when the RPM comes down off 5k. If you used wheel instead of engine braking, you would never notice the popping.
I run a 96 Super Glide with a 96 inch motor. Been 10, 15 years and i have had no cracks on my Thunder header. Use grade 8 exhaust bolts. Put your pipe on loose. Connect the pipe to the cylinder head first, jiggle the pipe to get it tight use lock washers and proper bolts they are oblong so they stay put. After you done ride for ten min and tighten them all again.
I've had two different T-headers and a Supertrapp Supermeg on my 2000 FXD. I had fairly regular breakage of the original bracket but, once they added in some gusseting I no longer had any breaks. I wish I could attach some pictures to explain what I'm talking about. Anyway, it's not uncommon in my experience (and friends) to have cracks form in the bracket and I could usually tell by the seat of my pants when it did. The bracket that came with the Supertrapp is such a beefy and well designed piece I can't see it ever breaking. It's strength is in the up and down motion from rubber mounted engines. I might be able to round up some pics if you want.
