Taller shocks = shorter ranger?
Old Jul 6, 2017 | 12:31 PM
wyotana's Avatar
wyotana
Default Taller shocks = shorter range?
Range, not ranger...stupid phone
So I've recently thrown some 13.5" shocks on the my 03 FXD, and while I love the look and feel I've noticed I seem to be getting shorted about a half a gallon when I gas up. Before the switch when I would fill up at reserve I was able to put right at 4 gallons in, since the switch it's been 3.5 gallons. I'm not sure if it's because of the angle of the tank while I ride is letting less fuel get to the petcock, or if it's because the bike leans more I'm able to put less in the tank, or a combination. Anyone else experience this? If so is the solution a tank lift, or just deal with the shorter range? And will it effect how many miles I can get out of reserve?
thanks guys
Old Jul 6, 2017 | 12:34 PM
DynaKid94's Avatar
DynaKid94
never thought of this honestly...can't see it making too drastic of a difference but I'm curious to see what others have to say, as I've gone with taller shocks too...
Old Jul 6, 2017 | 07:36 PM
HD_Matt's Avatar
HD_Matt
If you stand the bike up straight while you are fueling it, you can get quite a bit more in the tank.
Old Jul 6, 2017 | 08:48 PM
fxdlx's Avatar
fxdlx
So, if the gas cap is the highest point on the tank when filling(like when on side stand) you get less gas than when the bike is level? How dat wurk?
Old Jul 6, 2017 | 11:28 PM
wyotana's Avatar
wyotana
Mine has the gas cap in the middle not on the right hand side like many others.
Leveling it out when I fill it up would probably make a good difference as long as I left right after filling up, maybe I'll start doing that. Otherwise as soon as I learn it over on the stand it will flood out the overflow tube
Old Jul 7, 2017 | 12:24 AM
Smogbob's Avatar
Smogbob
Well if there is a logic to this it would be, you raised the rear 1 inch, so if you raised the tank at the front 1 inch all should be back to normal.
Old Jul 7, 2017 | 07:48 AM
leafman60's Avatar
leafman60
Well, if you added 1.5 inches to your rear suspension, the swing arm geometry is likely to increase ride height by more than that amount (assuming your rear sag is not too soft). I assume that this increased rear height is tipping your tank orientation up in the rear and causing your issue. I wouldn't think that such a difference would be detected but perhaps so.
I've jacked up my Super Glide that much or more but haven't noticed a tank fill change.
By the way, with that increased rear height, you probably notice quicker steering since your front wheel has been steepened in angle and reduced your trail distance.
Old Jul 7, 2017 | 08:46 AM
beanoboy's Avatar
beanoboy
This...b.
Old Jul 7, 2017 | 10:42 AM
wyotana's Avatar
wyotana
That was my thinking as well
Old Jul 7, 2017 | 11:59 AM
HD_Matt's Avatar
HD_Matt
My fxd has the cap in the middle as well.
