Ness Big Brake Single Caliper on Dyna
Sumbich hauls down quick now. I also like the clean look of a single disc as well as the minimized un-sprung weight it offers.
Nicely done, you will love that Arlen Ness Big Brake! Like robbyville I'm using Lyndall organic pads, the added braking control with the Big Brake is well worth the money spent. My maximum/threshold braking distances shorted up even further with the addition of the Big Brake rotor.
With that added braking have you done any upgrading to your front forks? If not, you should consider it; the braking control becomes even more enhanced with a front end that's working properly and not bouncing up and down or suffering from excessive fork dive under heavy braking.
Good performing tires, upgraded front suspension, quality rotors, brake pads and a bit of time practicing your heavy braking; you can haul these big cruisers down with a quickness
Those Big Brake rotors sure are pretty...
Stopping power is a relative term; even the stock rotor, caliper, and pads can completely lock up the front so the 'stopping power' is there, this is all about added braking control. The sintered brake pads will have a higher initial bite, the organics have a lower initial bite and ramp up progressively; organics will give you better feedback and 'feel' at the brake lever under heavy braking. No ABS on my Wide Glide and I can feel where that braking threshold point is; the kinetic friction of a rolling tire will stop you much faster than the static friction of a sliding tire
This is all in what you're accustomed to, some prefer that heavier initial bite, some prefer the added control. Either way, upgrading your braking is always money very well spent
https://www.hdforums.com/forum/dyna-...l#post14661483
it's a lie!
Fun fact, Lyndall was created by ex Porterfield guys.
You'll notice the Ohlins shocks on the rear. I jacked the bike up 2-3 inches. Also, I have the Sputhe stabilizers on it.
Check out those Continental Trail Attack 2 adventure tires. Amazing grip on pavement. They have a nice rounded profile and allow extreme lean angles at speed. I have another thread on those.
It'll keep up with the BMW's and Guzzi's that I have now.
I also breathed on the motor within reason. I upgraded it to 103 inches. The heads are milled down and I have a set of SE204 cams (perfect) along with a V&H FP3 tuner (wonderful device) to match the V&H exhaust. K&N with open back cover. Power output was increased dramatically. Dramatically. It pulls hard and steady all the way to 6k. On the curves, 3rd gear carries me from 35 to 100 in a huuuurrryyyy.
The suspension upgrades allow effective use of that power
