Electrical Gremlin
Old Jul 23, 2017 | 09:06 AM
Vegas0624's Avatar
Vegas0624
Stage I
Default Electrical Gremlin
I recently swapped out my handlebars and reran the internal wiring. I ended up having to use waterproof connectors to connect all the handlebar wired to the harnesses. Now after a while of riding I get a check engine light and then the battery light and red dot on speedometer come on. Once this happens my speedometer and light cut out then come back on. What is going on and how can I fix it?
Old Jul 23, 2017 | 10:27 AM
archergodwin's Avatar
archergodwin
Fine...
Old Jul 23, 2017 | 12:02 PM
nevil's Avatar
nevil
Year and model?
Did you disconnect the battery first?
Canbus wiring is not like serial bus wiring.
Obviously you did something wrong when you wired the bars. Pinched wire, loose connection, etc. Go back over it and check every wire and connection carefully. Use a DVM to check continuity.
probatebob
Feb 7, 2012 06:40 PM
purplehog
Jun 11, 2011 02:31 PM
marinepilot81
May 29, 2009 01:02 AM
8541hog
Mar 12, 2009 11:29 AM
zenwarrior
Apr 29, 2007 08:57 PM
