Rear Wheel Removal
Old Aug 4, 2017 | 04:08 PM
Sparra's Avatar
Sparra
Default Rear Wheel Removal
Hi folks...Going to remove my rear wheel,2010 Wideglide..to replace the tyre,,,Is there an easy way to re-align it when I put it back on??
Cheers...
Old Aug 4, 2017 | 04:38 PM
Nickd2689's Avatar
Nickd2689
I just mark 12 o clock on both bolts and count the amount of turns they come out (they should be the same) then put them back in the same way and check belt deflection. Very easy. Otherwise you can simply rotate each one one full turn at a time until the belt gets tight, then check/adjust deflection. It's very easy.
Old Aug 4, 2017 | 05:08 PM
TinCupChalice's Avatar
TinCupChalice
Cheers...
Dyna owner must have's; do it right, that rear wheel alignment is critical to the correct handling of the Dyna
https://www.motionpro.com/product/08-0368
https://www.motionpro.com/product/08-0350
Old Aug 4, 2017 | 05:39 PM
emperor wurm's Avatar
emperor wurm
you can make an alignment tool with a coat hanger and a valve stem cap. Free and works just as good.
Old Aug 4, 2017 | 06:00 PM
mirrmu's Avatar
mirrmu
dont touch the alignments blocks, lift bike up to sweet spot and it will come out fine
Old Aug 4, 2017 | 06:57 PM
TinCupChalice
Well, sure, you can But.... tools
Old Aug 4, 2017 | 07:48 PM
Kraken's Avatar
Kraken
Add the V-Twin mfg or Jim's axle plugs too. I'd rather use a coat hanger and those than the Motion Pro tool with tape or something and it's about the same cost as the V-Twin plugs. Who am I kidding, I have all 3 because I'm a tool ***** too
Old Aug 4, 2017 | 08:54 PM
loopie's Avatar
loopie
the easy way is while drinking a cup off coffee, get the tyre dealer too supply and fit
Old Aug 4, 2017 | 11:05 PM
archergodwin's Avatar
archergodwin
Mine is a piece of brazing rod, with a tie-wrap on tight, but can slide....
and it is a tool... and works just as well as any other over priced piece of wire made by someone else.
I've had my wheel off several times, and my little brazing rod lines it back up just fine...
Knowing how much deflection a 10lb weight will give your belt, and adjusting to that deflection...without a tool.
yes, tools are good... and the right tool makes a tough, complex job much easier... removing/installing a rear wheel is neither tough, nor complex.
Old Aug 5, 2017 | 06:58 AM
Dynafast's Avatar
Dynafast
6th Gear
Grease the axle so it comes out easy again. Made that mitqke has to use a slide hammer to get it out. Then put in the other way when went to a 180 nightdragon in the rear.
