handlebars on a streetbob
Old Jun 11, 2007 | 03:48 AM
moonsfmc's Avatar
moonsfmc
Default handlebars on a streetbob
i was wanting to know what these bars are in length factory on a 2006 street ?? 12", 14", or maybe something else. thanks
Old Jun 11, 2007 | 04:30 AM
burzerko29's Avatar
burzerko29
Default RE: handlebars on a streetbob
I posted the same question a while back. Your talking about the mini apes right? the answer i got was 10.5 inches. I measured and it seemed correct.
Old Jun 11, 2007 | 04:41 AM
moonsfmc's Avatar
moonsfmc
ok thanks so ican assume that for every inch taller i go i will need to add that much to my new cable length and i am asking this question because i know what assume can get me!!!!
Old Jun 11, 2007 | 09:55 AM
Chipstah's Avatar
Chipstah
I believe if you look at your cables, with the exception of the brake line which can be bent a little, you have roughly at least 1" up to 2" of slack, so depending on how much higher you want to go, you might not need to replace them inch of cable for inch of rise. But to be safe, certainly your assumption should work - only variable might be if you're thinking of more pull back distance in the bars. I only need to go up another inch or two vertical and am planning on just getting some new risers of no more than 4" (stock are 2") so I don't have the long install process and hassle/expense of changing over controls, lines, etc. And if that doesn't give me enough height (but I think it will), then I'll be looking at new bars. But that's just me!
And if you really don't want to have to worry about it - here's a company on eBay that figures it all out for you. You just tell them what you have and what you want and they do the rest and put together a whole kit for you - bars, cables, etc. Typical listing:
http://cgi.ebay.com/ebaymotors/ws/eB...8377209&rd=1,1
Chip
Old Jun 11, 2007 | 01:07 PM
deeblues's Avatar
deeblues
Very good find my man Chipstah !!!!!
That's is just what I'm looking for in BLACK !!!!
Do you or anyone know what size apes are on the stock 07 Bob???....I would figure 10 inch with a 2 inch riser????
Again great find plus you get the benefits of fat looking bars..
[IMG]local://upfiles/23685/0F2BC17D25094B098EEE8923B1A0A4F3.jpg[/IMG]
[IMG]local://upfiles/23685/E69D841BFBA44BB58E2E86D80CAF0BEF.jpg[/IMG]
Old Jun 11, 2007 | 01:47 PM
TattooedAndScarred's Avatar
TattooedAndScarred
You should be able to get narrow glide 12's on w/o changing anything....i was able to get 13's on, only thing i had to do was bend the metal part of the brake line a bit!
[IMG]local://upfiles/3645/309D234F1B93437F9453FD40F5894260.jpg[/IMG]
Old Jun 11, 2007 | 01:52 PM
anubisss's Avatar
anubisss
There is also someone who sells apes on ebay complete with switch housings and wiring but not the throttle cables and brake line for about the same price. I'll see if I can find it. It looks like the same place...
http://cgi.ebay.com/ebaymotors/Harley-1-1-4-Ape-Hangers-Handlebar-Controls-PACKAGE_W0QQcmdZViewItemQQcategoryZ35564QQihZ020QQ itemZ300119802880QQrdZ1QQsspagenameZWDVW
TechSlave 71
May 13, 2019 06:27 PM
TejasJeff
Jul 25, 2018 01:01 PM
carrmat
Apr 16, 2013 12:49 PM
ghoticov
Mar 8, 2013 04:45 AM
Xenomorph
Mar 9, 2010 10:20 AM
