Turn Signal Pin Removal
Old Aug 30, 2017 | 03:05 PM
MotorpsychoNightmare's Avatar
Stage III
Default Turn Signal Pin Removal
Howdy! I know there are a ton of threads on this subject already, but none them seem to be helping me at all. I'm replacing my handlebars and I need to remove the turn signal wires from the housing. I've tried using a tiny jewelers screwdriver and a flattened paper clip. I cannot seem to get any of these damn wires to budge! Has anyone ever ran into this problem?
Old Aug 30, 2017 | 03:45 PM
Stage III
Never mind. Figured it out and it was simple. I didn't realize I had to push the wire forward with the safety pin stuck inside before pulling the wire out. Hope this helps someone else. That was frustrating as well for a while.
Old Aug 31, 2017 | 12:47 AM
Fireguy88's Avatar
Fireguy88
Glad you figured it out. I use a sewing needle. Push needle in, lift up a bit. Push wire side in simultaneously and then pull out. Once you get the trick of it, it's quite easy.
TylerBoehm
Feb 13, 2014 06:39 PM
ghoticov
Sep 3, 2012 01:55 PM
ZeroFiveFour
Oct 28, 2010 07:52 PM
zramey4
Oct 11, 2010 08:59 PM
2005sporty
May 13, 2008 04:45 PM
