Dreaded Dyna Vibration
Old Jan 1, 2018 | 02:28 PM
Huggerbugger's Avatar
Huggerbugger
Originally Posted by TinCupChalice
Oh, you can pretend all you want; claim all those epic HD's in your garage, I know it's all nothing but bullshit.
You don't know the first thing whatsoever about a Dyna, or how to actually make one perform.
Go ahead and rock that '18; you'll jack it up as well...
You antique dipshit...
Old Jan 20, 2018 | 01:00 PM
Lifestarts@40's Avatar
Lifestarts@40
Update... I took the bob into the dealer. One of the techs is a close friend of mine. He called after a bit and said he ordered a new front isolator. Along with that, he's replacing both of my throttle cables. Both cables were losing the black coating on their outsides as if they were rubbing but don't rub.
So I went back and picked it up and will take it back when the parts come in. That's the first time I've had to use warranty.
Old Jan 20, 2018 | 01:14 PM
Huggerbugger
I put a new front isolator on last week and vib was worse! Put shims in and we'll see if that helps.
Old Jan 20, 2018 | 09:19 PM
Huggerbugger
Interested to hear how that works out for ya.
Old Jan 20, 2018 | 09:42 PM
IdahoHacker's Avatar
IdahoHacker
It seems my ride picked up the dreaded vibration. It rattle my boots on the pegs pretty good between 2200 and 2500 rpm. I'm guessing my mounts may need to be re torqued. I'd appreciate any insights you guys can offer. Thanks!
Had exactly the same problem on my '14 Super Glide Custom. Traded it in on my Road Glide. Problem fixed. j/k!
Keep us posted!
Old Jan 30, 2018 | 12:24 PM
Lifestarts@40
Update...
Took it back in today to have new frt. isolator installed. Problem solved! It still has the dyna buzz between 2200-2400 rpm but no longer rattles my boots. Decel vibration is totally gone too.
If there's a next time anytime soon, I'll update the front mount with a predator. For now I'm quite happy.
Old Jan 31, 2018 | 01:53 PM
crzoomb's Avatar
crzoomb
Under “required dealer action” #2...what is the rear fork they speak of?
Old Jan 31, 2018 | 02:14 PM
TinCupChalice's Avatar
TinCupChalice
The rear fork is HD speak for the swingarm...
http://partsfinder.onlinemicrofiche....ND%20DEFLECTOR
Old Jan 31, 2018 | 02:25 PM
Lifestarts@40
I just got back from the gym. The bike is definitely better. What used to rattle my boots on the pegs is now a mild buzz. Way better.
Old Jan 31, 2018 | 04:06 PM
Bob_fxdb's Avatar
Bob_fxdb
Change it out with a proper non hd motor mount. It will not only reduce the dreaded vibration, it will also improve handling and general wear and tear of the hd mounts. Thats on my next list. The part 2018 fat bob its too expensive for me...
