rear end clunk big bear motor mounts
Old Nov 8, 2017 | 03:51 PM
paulvs's Avatar
paulvs
Stage II
Default rear end clunk big bear motor mounts
2013 FXDX Fatbob with front and rear big bear motor mounts, rear end clunks over slow bumps, anyone else have this issue?
Old Nov 8, 2017 | 04:43 PM
F86's Avatar
F86
For better or worse, I don't think many people have the "issue" of having front and rear BBC motor mounts...
Sorry, I realize I'm not being helpful... Did the issue start at the same time as the mount installation? I'm not super familiar with the BBC rear mount, but I'm under the impression that it's stiffer overall than the OEM unit... If so, something else may have started taking up some of the damping duty abandoned by the mount... Also, is the engine/tranny/swingarm properly aligned in the frame? I don't mean to be insulting, but are you sure that everything is tightened and torqued properly?
This isn't really the "rear end," but it's not uncommon that the top of the side stand can start clunking against the case if the relationship lbetween engine and frame is altered at all (as in changing mounts)...
Old Nov 8, 2017 | 04:58 PM
misfitJason's Avatar
misfitJason
Generally two things.
1. Is the kickstand pin hitting and is the right direction
2. Was an alignment (motor) done after the mounts were in. If it’s the mount contacting something (motor/trans to rear frame) do another one
Old Nov 8, 2017 | 06:54 PM
loopie's Avatar
loopie
do a search on the company, most customers off them experience rear end problems ,,, REAR end (***) problems after being *** raped by them ,,, hhhaaaa
nbowen805
Feb 8, 2018 10:43 PM
johnod
EVO
Sep 16, 2014 07:35 AM
Son of PMS
EVO
18
Jul 22, 2014 08:39 PM
skyntback
Sep 4, 2009 08:03 AM
magna3500hd
Jan 7, 2007 08:21 AM
