FXDLS MX Grips
Old Nov 13, 2017 | 11:22 PM
Dicko2289's Avatar
Dicko2289
2nd Gear
Default FXDLS MX Grips
Hey guys,
Trying to figure out a way of throwing some MX grips on my FXDLS but coming up with nothing other than trying to stretch them over a Drag Specialties 1.4" sleeve.
Surely there's an easier way!!
Cheers,
Joel
Old Nov 14, 2017 | 06:34 AM
Langen's Avatar
Langen
Boiling them 15-20 Minutes makes it easier to pull them over the handlebar.
Old Nov 14, 2017 | 07:17 AM
BMyers's Avatar
BMyers
blowing compressed air into the grip as you slide it on.
start @ 1:20
Old Nov 14, 2017 | 12:56 PM
DOM8R's Avatar
DOM8R
Stage IV
I could not find any 1" grip that I liked better than soft MX grips. Just boiled standard 7/8" MX grips and stretched them over the bars and throttle sleeve. I had the sleeve off the bar when doing it.
Old Nov 14, 2017 | 04:45 PM
shibbby911's Avatar
shibbby911
I put mx grips on my bike easy only using hair spray
Old Nov 14, 2017 | 04:50 PM
Dicko2289's Avatar
Dicko2289
2nd Gear
Cheers fellas, I'm guessing you just cut the grips off the stock tube and used that?
I'll give it a crack and let ya's know.
Thanks Again!!!
Old Nov 14, 2017 | 05:01 PM
shibbby911's Avatar
shibbby911
Thanks Again!!!
Ya I cut the stock grip off
Old Nov 14, 2017 | 07:25 PM
DOM8R's Avatar
DOM8R
Stage IV
I used a fresh throttle sleeve, cut them before for standard grips.
Old Nov 14, 2017 | 07:27 PM
DOM8R's Avatar
DOM8R
Stage IV
Thanks Again!!!
Those look great, your probably stronger than me. Haha. I really had to heat mine to have any chance to get them on.
Old Nov 15, 2017 | 04:39 PM
End Loser's Avatar
End Loser
Fyi DOM8R, the LRS has throttle by wire which is a bit different than the tube sleeve you're referring to.
I was wanting to put MX grips on my LRS as well, but was hesitant because of the TBW, but now that I see it can be done, I may just do this!
shibbby911, are there any issues at all? How many miles have you put on since the new grips?
