How to enable EITMS on 2017 FXDF Fat Bob
Old Nov 25, 2017 | 08:53 PM
tnichols's Avatar
tnichols
Default How to enable EITMS on 2017 FXDF Fat Bob
I have been trying to enable the EITMS on my 2017 Fat Bob FXDF.
I turn the ignition on.
I turn the run switch to run.
I roll back the throttle and hold for 5 seconds.
and nothing. No flashing lights. Just nothing.
Do I have to go to the dealer to have them enable it. Or am I doing something wrong?
signed,
Confused...
Old Nov 25, 2017 | 09:03 PM
cbrenthus's Avatar
cbrenthus
I don't know about the fat bob, but on the touring model you roll the throttle forward. The opposite direction from giving it the gas.
Old Nov 25, 2017 | 09:39 PM
tnichols's Avatar
tnichols
Yep, that's what I did. Maybe the bike needs to be throttle by wire and mine still uses cables.
Old Nov 25, 2017 | 09:41 PM
martinj's Avatar
martinj
With throttle by wire, you can enable it by rolling the throttle full forward, as previously indicated. Unless something has changed between the '16 and the '17 models, the dealer has to enable the throttle by cable versions for you, unless you have a flash tuner that is capable of enabling it for you (for example, PowerVision).
Old Nov 26, 2017 | 07:23 AM
tnichols's Avatar
tnichols
Thank you. That must be the answer. The dealer must have to do it on my 2017 Fat Bob. That will be a pain, to have to go to the dealer to have it turned on and off. It would be much better if the user could enable and disable it themselves.
I wonder what the dealer charges for that change?
Old Nov 26, 2017 | 10:27 AM
martinj's Avatar
martinj
Good question, and one I unfortunately don't have the answer for. I'm betting my dealer would probably do it for free, but I'm also betting that a lot of them would charge something for it. I can't see it taking more than five minutes or so....
Old Nov 27, 2017 | 05:35 AM
1HD1C's Avatar
1HD1C
it is 1/2 hour labor at most shops..
do you have a tuner?? if so check as I believe some of them have that ability now..
FP3 is one of them
Old Nov 28, 2017 | 07:32 AM
tnichols's Avatar
tnichols
Nope...I am not sure what a tuner is... The is my first new Harley since 1970. Mine is still 99.9% stock. (I removed the passenger strap). My passenger never uses them and I think it looks better/cleaner without the strap.
Old Nov 28, 2017 | 09:00 AM
TinCupChalice's Avatar
TinCupChalice
The bikes ship extremely lean due to EPA requirements; a tuner, such as a Power Vision flash tuner replaces the OEM tune with one that actually lets the bike perform and run cooler. Even completely stock, a flash tuner will make a world of difference in your ride's performance...
Old Nov 29, 2017 | 08:39 AM
tnichols's Avatar
tnichols
Oh! Thank you... I will have to look into a tuner. Someone told me that changing the tuner will void the warranty. I can tell its lean. The engine wants to surge or hesitate. My 1970 Ironhead is smoother.
I also wonder if a tuner will work with the stock pipes. I like the looks and sound of the stock exhaust and have no plans on change it.
