Brake Systems
Old Nov 29, 2017 | 10:27 AM
F86's Avatar
F86
Originally Posted by nevil
Yes, really. The stainless brake line helps but nowhere to the degree that big rotor does. I was thinking about going to dual rotors but after I installed this I realized it was all I needed.
A stainless line will improve lever feel and possibly help the rider's ability to modulate pressure at the limit, but it does nothing to actually improve the bike's ability to stop. The only difference between braided and rubber occurs during the time the rubber line is expanding... Once it's fully pressurized, it really behaves the same as a braided line (unless it's in bad shape). The big rotor kit actually increases the swept area of contact between pad and rotor considerably, thus having a significant impact on performance. There is simply a lot more rotor passing between the pads for any given amount of distance traveled.
Old Nov 30, 2017 | 05:57 AM
Vec's Avatar
Vec
Exclamation
thanks for the info, now best price search begins!
Old Nov 30, 2017 | 06:16 AM
nevil's Avatar
nevil
I got mine from Phat Performance. At the time it was about $165.
Sorry, that was a typo. It was $265.
Old Nov 30, 2017 | 06:17 AM
TinCupChalice's Avatar
TinCupChalice
Add me to the list of very happy Big Brake rotor owners F86 nailed it with his post, the Big Brake is worth the price of admission. I do practice max/threshold braking from highway speeds down to parking lot speeds and the rotor does make a substantial difference in braking distances.
I'm also using Lyndall pads front and rear, they do provide a better 'feel' at the lever as you approach maximum braking. The Big Brake isn't difficult to install; you need to remove the front wheel, mount the new rotor to the wheel, mount the caliper adapter to the slider, mount the wheel, and mount the caliper to the adapter.
Check Phat Performance for best pricing on the Big Brake kits; the price has increased since I bought mine but I'd still do it again without hesitation: http://www.phatperformanceparts.com/...rake-rotor.htm
You can see in this image how the caliper adapter is mounted:
Old Nov 30, 2017 | 10:20 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome to the site.
Ride safe!
Old Nov 30, 2017 | 01:18 PM
F86's Avatar
F86
Honestly, if price is an issue (which it always is), you might start by upgrading the pads and completely flushing the system with fresh fluid. Pads from Lyndall or EBC can make a noticeable difference for a very reasonable cost. And I'm constantly amazed at how much better everything feels after a good flush and thorough bleeding... I don't know exactly what your braking goals are, but you might be satisfied with the result of some pretty simple upgrades...
Old Dec 3, 2017 | 06:55 AM
Vec's Avatar
Vec
price has never been an issue with me, I could buy directly from Ness and sleep well, I just dont like to overpay for the same product because that doesnt leave any extra on the table for other parts.
this bike was already upgraded to better lines when I got it in June and I did a flush on both ends of the bike when I changed out the rear caliper in July because it was hosed up. and it does stop well, but if this will make it stop BETTER and look a little different... why not?
on the arlen ness site the kit i like the look of is PN# 02-994 the wave rotor style
when looking at PHATs site I dont see it listed at all and its confusing as they list FLT and softail
Old Dec 3, 2017 | 07:16 AM
cvaria's Avatar
cvaria
send them an email at sales@phatperformanceparts.com attn Terry. He owns the joint and will send mails and make calls to get you what you need. Between him and Ness, I got all 4 of my waved rotors for an ungodly low price. 02-994 is the left rotor and adapter kit for 06+ dynas and 15-17(cant confirm 18) sloptails.
We are business men, price is always an issue because there's always another upgrade and running you mouth gets you deals that save money for the next upgrade. Never pay retail.
Old Dec 5, 2017 | 08:13 PM
multihdrdr's Avatar
multihdrdr
FWIW in regards to all this Big Ness "Talk" and the OP's 96 Dyna
Big Ness No Worky on 99-earlier Bikes
Old Dec 5, 2017 | 08:53 PM
REW13's Avatar
REW13
Man I almost woke my wife laughing at this post..
